sudo pip3 install git+https://github.com/plamere/spotipy.git
I already have this installed so I will try and re-install it and return with an update. Thank you.Ewaldharmsen wrote: ↑Tuesday 02 April 2019 12:12 please install Spotipy properly:Code: Select all
sudo pip3 uninstall spotipy
can you update the plugin to version 4.4.0? That should solve the issue, or should show the problem.
2019-05-09 16:32:14.933 Error: (Chromecasts) Error on line 413 Error is 'BasePlugin' object has no attribute 'ConnectedChromecasts'
Error: (Chromecast) pychromecast is not up to date, it is currently version 3.2.2 it should be at least version 3.2.1. Please upgrade by using this command: 'sudo pip3 install pychromecast --upgrade' and restart this plugin.
sudo pip3 install --force-reinstall pychromecast==3.2.1
sudo service domoticz.sh restart
Is not really helpfull for me..Just add a value to the created variabele and the text will be spoken.
I use it voor voice messages and fill the variable from a lua script
2019-05-27 09:41:41.424 Error: (Chromecast Plugin) pychromecast is not up to date, it is currently version 3.2.2 it should be at least version 3.2.1. Please upgrade by using this command: 'sudo pip3 install pychromecast --upgrade' and restart this plugin.
Fixed in version 4.4.1, You need to install "sudo pip3 install packaging"schulpr wrote: ↑Friday 24 May 2019 7:31 Hi,
I'm getting this error:Updating as suggested doesn't solve it. Any solution?Code: Select all
Kind regards, Rob
Of course,
2019-06-03 15:53:47.672 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:53:47.672 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:53:47.672 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:15.712 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:15.712 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:15.713 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:29.715 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:29.716 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:29.716 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:43.719 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:43.719 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:43.719 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:57.729 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:57.729 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:57.729 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:13.414 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:13.415 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:13.415 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:27.418 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:27.418 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:27.418 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:41.429 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:41.430 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:41.430 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:55.433 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:55.433 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:55.433 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:09.436 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:09.436 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:09.436 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:23.441 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:23.441 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:23.442 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:37.445 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:37.445 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:37.445 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:51.448 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:51.449 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:51.449 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:57:05.452 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:57:05.452 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:57:05.452 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:57:19.455 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:57:19.455 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:57:19.456 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
Solved my issue, had to put the correct name of the chromecast in the hardware tab.So can anybody explain to me step by step how to send a message to the chromecast?
The description of the TS / author of the plugin in one of the first posts on this topic:Is not really helpfull for me..Just add a value to the created variabele and the text will be spoken.
issue.the whole python plugin framework crashes and the plugin no longer works including all my other plugins
Ewaldharmsen wrote: ↑Monday 10 December 2018 14:23 I just have released version 3.0.1.
You can now update the hardware without the need to restart domoticz.
Devices which are no longer needed are automatically deleted
