sudo pip3 install git+https://github.com/plamere/spotipy.gitModerator: leecollings
sudo pip3 install git+https://github.com/plamere/spotipy.gitI already have this installed so I will try and re-install it and return with an update. Thank you.Ewaldharmsen wrote: Tuesday 02 April 2019 12:12 please install Spotipy properly:Code: Select all
sudo pip3 uninstall spotipy
great, just wondering when do you have time to implement this?Dnpwwo wrote: Tuesday 12 March 2019 11:30
I will add new aplications (as they are used) to the Source device in the next version.
can you update the plugin to version 4.4.0? That should solve the issue, or should show the problem.brain wrote: Sunday 28 April 2019 11:12 hi i am getting this error((chromecast) pychromecast is not up to date, please upgrade by using this command: 'sudo pip3 install pychromecast --upgrade) and pychromecast is up to date.
what can i do?
thanx
2019-05-09 16:32:14.933 Error: (Chromecasts) Error on line 413 Error is 'BasePlugin' object has no attribute 'ConnectedChromecasts'Code: Select all
Error: (Chromecast) pychromecast is not up to date, it is currently version 3.2.2 it should be at least version 3.2.1. Please upgrade by using this command: 'sudo pip3 install pychromecast --upgrade' and restart this plugin.Code: Select all
sudo pip3 install --force-reinstall pychromecast==3.2.1
sudo service domoticz.sh restartIs not really helpfull for me..Just add a value to the created variabele and the text will be spoken.
I use it voor voice messages and fill the variable from a lua script
2019-05-27 09:41:41.424 Error: (Chromecast Plugin) pychromecast is not up to date, it is currently version 3.2.2 it should be at least version 3.2.1. Please upgrade by using this command: 'sudo pip3 install pychromecast --upgrade' and restart this plugin.
Fixed in version 4.4.1, You need to install "sudo pip3 install packaging"schulpr wrote: Friday 24 May 2019 7:31 Hi,
I'm getting this error:Updating as suggested doesn't solve it. Any solution?Code: Select all
Kind regards, Rob
Of course,Dnpwwo wrote: Saturday 01 June 2019 23:52 @snellejellep,
Can you supply some details?
What version of the plugin are you using.
What version of Domoticz.
What platform you are running on.
Can you attach the log messages showing the framework crash.
2019-06-03 15:53:47.672 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:53:47.672 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:53:47.672 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:15.712 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:15.712 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:15.713 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:29.715 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:29.716 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:29.716 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:43.719 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:43.719 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:43.719 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:54:57.729 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:54:57.729 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:54:57.729 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:13.414 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:13.415 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:13.415 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:27.418 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:27.418 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:27.418 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:41.429 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:41.430 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:41.430 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:55:55.433 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:55:55.433 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:55:55.433 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:09.436 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:09.436 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:09.436 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:23.441 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:23.441 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:23.442 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:37.445 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:37.445 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:37.445 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:56:51.448 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:56:51.449 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:56:51.449 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:57:05.452 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:57:05.452 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:57:05.452 Error: Chromecast hardware (34) thread seems to have ended unexpectedly
2019-06-03 15:57:19.455 Error: xiaomi vacuum hardware (19) thread seems to have ended unexpectedly
2019-06-03 15:57:19.455 Error: Buienradar hardware (29) thread seems to have ended unexpectedly
2019-06-03 15:57:19.456 Error: Chromecast hardware (34) thread seems to have ended unexpectedlySolved my issue, had to put the correct name of the chromecast in the hardware tab.So can anybody explain to me step by step how to send a message to the chromecast?
The description of the TS / author of the plugin in one of the first posts on this topic:Is not really helpfull for me..Just add a value to the created variabele and the text will be spoken.
issue.the whole python plugin framework crashes and the plugin no longer works including all my other plugins
Ewaldharmsen wrote: Monday 10 December 2018 14:23 I just have released version 3.0.1.
You can now update the hardware without the need to restart domoticz.
Devices which are no longer needed are automatically deleted
