Sunrise time in text dummy
maceddy
Domoticz version: 12723
Post by maceddy »
Just for the fun of it:
Every morning I get a push message with tje current temperature. That works fine.
I would like, just for the fun, to include the sunrise time.
Is there a way to put the sunrise time in a text dummy? I tried with Set dummy to sunrise, but I get 'unknown comparevariable logic_sunrisesunset' as content in the text dummy.. I think there is some conversion to be done.. Is that even possible in blockly?
Re: Sunrise time in text dummy
I don't think it can be done in Blockly.
In dzVents it would look like the script below.
If you are not yet familiar with dzvents then please look at the 10 lines using dzVents with Domoticz for an intro to dzVents and howto get this script active in domoticz.
Before activating this script you need two text sensors; named Sunset and Sunrise.
    on          =   {   timer     =   { "at 00:03", "at 06:03" }}, -- twice a day to be sure and 3 min past the hour because at the hour already quite busy
    execute = function( dz )
        local function minutes2time(minutes)   -- integer in; string out
            local hour      = string.format("%02d",math.floor(minutes / 60))
            local minutes   = string.format("%02d",minutes - (hour * 60))
            return (hour .. ":" .. minutes) --  string out
        dz.devices("Sunset").updateText(minutes2time(dz.time.sunsetInMinutes))
        dz.devices("Sunrise").updateText(minutes2time(dz.time.sunriseInMinutes))
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
or in Lua if you fancy it.
Just change text device idx & time to run if you want to.
script_time_displaysunset.lua
local houroftheday = tonumber(os.date("%H"))
local minutesofthehour = tonumber(os.date("%M"))
local timeinminutes = (houroftheday *60) + minutesofthehour
local dawn = timeofday['SunriseInMinutes']
local dawnminute = dawn % 60
local dawnhour = (dawn - dawnminute) /60
--Change to suit--
local sunsetdeviceIDX = 508 --idx of text device
if(timeinminutes == 180) then -- 03:00 --Time to run script
	displaysunset = 'Sunrise: ' ..dawnhour.. ':' ..dawnminute
	commandArray[#commandArray+1] = {['UpdateDevice'] = sunsetdeviceIDX.. '|0|' ..displaysunset}
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Jubbes
Post by Jubbes »
is it possible to include civil twilight start and civil twilight end in the dzvents code?
Jubbes
Jubbes wrote: Wednesday 22 May 2019 13:38 is it possible to include civil twilight start and civil twilight end in the dzvents code?
Sure. (available in dzVents version >= 2.4.7)
-- dzVents version >= 2.4.7
    timer     =   { "at 00:03", "at 06:03" }, -- twice a day to be sure and 3 min past the hour because at the hour already quite busy
        dz.devices("Sunset").updateText("Sunset: " .. minutes2time(dz.time.sunsetInMinutes).. "\nCivil twilight end: " .. minutes2time(dz.time.civTwilightEndInMinutes or "-"))
        dz.devices("Sunrise").updateText("Sunrise: ".. minutes2time(dz.time.sunriseInMinutes).. "\nCivil twilight start: " .. minutes2time(dz.time.civTwilightStartInMinutes or "-"))
Jubbes
Post by Jubbes »
Perfect waaren,
i have one button for one astro event:
dz.devices("Civil Twilight End").updateText(minutes2time(dz.time.civTwilightEndInMinutes))
dz.devices("Civil Twilight Start").updateText(minutes2time(dz.time.civTwilightStartInMinutes))
is it possible to add nautical twilight start/end and astronomical twilight start/end for four buttons?
Thank you,
jubbes
Jubbes
Post by Jubbes »
I mean what is the short Name from Nautical and Astronimical Twilight for the Script like civTwilightEnd ?
Jubbes wrote: Friday 24 May 2019 9:31 I mean what is the short Name from Nautical and Astronimical Twilight for the Script like civTwilightEnd ?
There is none in dzVents but I am trying to get it in another way. Script should be available today.
Jubbes
Post by Jubbes »
2.4.19
Jubbes wrote: Friday 24 May 2019 10:072.4.19
Posted the revised script in dzVents examples
Jubbes
Post by Jubbes »
Cool, thank you.
