Sunrise time in text dummy
- Domoticz version: 12723
Just for the fun of it:
Every morning I get a push message with tje current temperature. That works fine.
I would like, just for the fun, to include the sunrise time.
Is there a way to put the sunrise time in a text dummy? I tried with Set dummy to sunrise, but I get 'unknown comparevariable logic_sunrisesunset' as content in the text dummy.. I think there is some conversion to be done.. Is that even possible in blockly?
- waaren
Re: Sunrise time in text dummy
I don't think it can be done in Blockly.
In dzVents it would look like the script below.
If you are not yet familiar with dzvents then please look at the 10 lines using dzVents with Domoticz for an intro to dzVents and howto get this script active in domoticz.
Before activating this script you need two text sensors; named Sunset and Sunrise.
on = { timer = { "at 00:03", "at 06:03" }}, -- twice a day to be sure and 3 min past the hour because at the hour already quite busy
execute = function( dz )
local function minutes2time(minutes) -- integer in; string out
local hour = string.format("%02d",math.floor(minutes / 60))
local minutes = string.format("%02d",minutes - (hour * 60))
return (hour .. ":" .. minutes) -- string out
dz.devices("Sunset").updateText(minutes2time(dz.time.sunsetInMinutes))
dz.devices("Sunrise").updateText(minutes2time(dz.time.sunriseInMinutes))
- Domoticz version: Latest β
or in Lua if you fancy it.
Just change text device idx & time to run if you want to.
script_time_displaysunset.lua
local houroftheday = tonumber(os.date("%H"))
local minutesofthehour = tonumber(os.date("%M"))
local timeinminutes = (houroftheday *60) + minutesofthehour
local dawn = timeofday['SunriseInMinutes']
local dawnminute = dawn % 60
local dawnhour = (dawn - dawnminute) /60
--Change to suit--
local sunsetdeviceIDX = 508 --idx of text device
if(timeinminutes == 180) then -- 03:00 --Time to run script
displaysunset = 'Sunrise: ' ..dawnhour.. ':' ..dawnminute
commandArray[#commandArray+1] = {['UpdateDevice'] = sunsetdeviceIDX.. '|0|' ..displaysunset}
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
is it possible to include civil twilight start and civil twilight end in the dzvents code?
Jubbes
Jubbes
- waaren
Sure. (available in dzVents version >= 2.4.7)
-- dzVents version >= 2.4.7
timer = { "at 00:03", "at 06:03" }, -- twice a day to be sure and 3 min past the hour because at the hour already quite busy
dz.devices("Sunset").updateText("Sunset: " .. minutes2time(dz.time.sunsetInMinutes).. "\nCivil twilight end: " .. minutes2time(dz.time.civTwilightEndInMinutes or "-"))
dz.devices("Sunrise").updateText("Sunrise: ".. minutes2time(dz.time.sunriseInMinutes).. "\nCivil twilight start: " .. minutes2time(dz.time.civTwilightStartInMinutes or "-"))
Perfect waaren,
i have one button for one astro event:
dz.devices("Civil Twilight End").updateText(minutes2time(dz.time.civTwilightEndInMinutes))
dz.devices("Civil Twilight Start").updateText(minutes2time(dz.time.civTwilightStartInMinutes))
is it possible to add nautical twilight start/end and astronomical twilight start/end for four buttons?
Thank you,
jubbes
Thank you,
jubbes
I mean what is the short Name from Nautical and Astronimical Twilight for the Script like civTwilightEnd ?
- waaren
There is none in dzVents but I am trying to get it in another way. Script should be available today.
- waaren
Posted the revised script in dzVents examples
Cool, thank you.
