Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
Great, let me know :)
mantoz
Post by mantoz »
Madgeni wrote: Sunday 05 May 2019 9:35 Great, let me know :)
For now I tried several times and it works with no error messages, so I assume the problem was there and is now solved.
mantoz
DewGew
Domoticz version: V4.10618
Post by DewGew »
Madgeni wrote: Saturday 04 May 2019 15:41
Re: cameras - i did look into it, i'm not sure the Domoticz API exposes a camera stream. i'll investigate
Domoticz uses javascript image frame by frame update. Not an actual video file like mpeg or similar.
Stimpy68
Post by Stimpy68 »
Are there any problems with Controlicz? Google home says that there is a problem reaching Controlicz, tries unlining and linking again, but it failes. Also, when I go to the website and try to view the devices it goes back to the login page...
Madgeni
Post by Madgeni »
Controlicz is up and working ok. Can you double check you can access your domoticz externally?
Stimpy68
Post by Stimpy68 »
I did, same problem. Test connection to domoticz, it says success. I go to devices and end up back up on the login page, on a mobile device I get the connection failed and then go to the login page.
I tried to link controlicz to google home and it says something went wrong after allowing access to controlicz.
Only thing I changed is the URL to domoticz (incl ssl certificate) and things now go through a reverse proxy, but every other app I use with domoticz has no problems with that and work just fine.
Madgeni
Post by Madgeni »
Ok, can you drop me a mail from your Controlicz profile, and I'll get on it
Stimpy68
Post by Stimpy68 »
Done!
Stimpy68
Post by Stimpy68 »
Okay, for people that are going to use HAproxy and Domoticz as a backend with Controlicz, don't forget to set the Domoticz backend as your default backend ;) Thanks @Madgeni for the assistance!
Madgeni
Post by Madgeni »
Stimpy68 wrote: Saturday 18 May 2019 12:23 Okay, for people that are going to use HAproxy and Domoticz as a backend with Controlicz, don't forget to set the Domoticz backend as your default backend ;) Thanks @Madgeni for the assistance!
My pleasure :)
QSKONE
Post by QSKONE »
Hi , when I add Controlicz user with users rights don't have connection. I tested main user - admin with admin rights works well. What is wrong?
Madgeni
Post by Madgeni »
Can you restart domoticz and try again?
f14driver
Post by f14driver »
I bought the software last week, had some issues with it and contacted support. Nick worked with me over the weekend to get the issue sorted (turned out to be 2 things, rights in domoticz are adjusted after a reboot of the service and too many devices for Google to handle).
Today it has been resolved, great support and the best 20 pounds I've spent in a long time.
Hats off to you sir, very pleased with the result and the support from madgeni :D :D :D :D
Diegotjes
Post by Diegotjes »
I am very keen with this service but i can't get it working. I tried al settings but still it doesn't work.
I have an issue with getting the account settings correct. Can somebody help me out with it. It looks like everything is okay, but still i can't sync my devices. Maybe it is something easy
When i try to test the connection on controlicz.com nothing happens, and when i press devices i am kicked out immediately, and i have to login again. I haven't have a paid account yet, is it that needed to have this to sort out this problem?
jessy1984
Post by jessy1984 »
hi im trieing to use controlicz
first i had a message that https adress was incorect seemed i had to change the port.
now i get the message when i test connection
Check your connection setup
what dous it even meen why isnt there any info where i can check it
Madgeni
Post by Madgeni »
jessy1984 wrote: Sunday 02 June 2019 10:41 hi im trieing to use controlicz
Hi - mail me from your Controlicz profile, and we'll get it working :)
stevefury
Post by stevefury »
hi Madgeni,
im getting trouble also now with the connection, unlink and now i can't relink in google home.
can you help please, because i think its nothing to do here, it was working and 1 hour after it stopped doing some things!
thx
Madgeni
Post by Madgeni »
stevefury wrote: Tuesday 04 June 2019 11:22 hi Madgeni,
thx
hi - sure, just drop me a mail from your Controlicz profile, and i'll take a look
Varazir
Post by Varazir »
Hmm, I'm sure I saw the scens/groups as objects yesterday in the Google Home app.
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Madgeni
Post by Madgeni »
Varazir wrote: Monday 01 July 2019 12:23 Hmm, I'm sure I saw the scens/groups as objects yesterday in the Google Home app.
i'm on v 2.12.1.7 of the Home app, and still no scenes/groups are viewable (without going into Explore>Settings>Assistant>Home Control. annoying!
