Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Great, let me know
- DewGew
- Domoticz version: V4.10618
Domoticz uses javascript image frame by frame update. Not an actual video file like mpeg or similar.
Are there any problems with Controlicz? Google home says that there is a problem reaching Controlicz, tries unlining and linking again, but it failes. Also, when I go to the website and try to view the devices it goes back to the login page...
Controlicz is up and working ok. Can you double check you can access your domoticz externally?
I did, same problem. Test connection to domoticz, it says success. I go to devices and end up back up on the login page, on a mobile device I get the connection failed and then go to the login page.
I tried to link controlicz to google home and it says something went wrong after allowing access to controlicz.
Only thing I changed is the URL to domoticz (incl ssl certificate) and things now go through a reverse proxy, but every other app I use with domoticz has no problems with that and work just fine.
Ok, can you drop me a mail from your Controlicz profile, and I'll get on it
Okay, for people that are going to use HAproxy and Domoticz as a backend with Controlicz, don't forget to set the Domoticz backend as your default backend
Thanks @Madgeni for the assistance!
My pleasure
Can you restart domoticz and try again?
I bought the software last week, had some issues with it and contacted support. Nick worked with me over the weekend to get the issue sorted (turned out to be 2 things, rights in domoticz are adjusted after a reboot of the service and too many devices for Google to handle).
Today it has been resolved, great support and the best 20 pounds I've spent in a long time.
Hats off to you sir, very pleased with the result and the support from madgeni
I am very keen with this service but i can't get it working. I tried al settings but still it doesn't work.
I have an issue with getting the account settings correct. Can somebody help me out with it. It looks like everything is okay, but still i can't sync my devices. Maybe it is something easy
When i try to test the connection on controlicz.com nothing happens, and when i press devices i am kicked out immediately, and i have to login again. I haven't have a paid account yet, is it that needed to have this to sort out this problem?
hi im trieing to use controlicz
first i had a message that https adress was incorect seemed i had to change the port.
now i get the message when i test connection
Check your connection setup
what dous it even meen why isnt there any info where i can check it
Hi - mail me from your Controlicz profile, and we'll get it workingjessy1984 wrote: ↑Sunday 02 June 2019 10:41 hi im trieing to use controlicz
hi Madgeni,
im getting trouble also now with the connection, unlink and now i can't relink in google home.
can you help please, because i think its nothing to do here, it was working and 1 hour after it stopped doing some things!
thx
thx
hi - sure, just drop me a mail from your Controlicz profile, and i'll take a look
- Varazir
Hmm, I'm sure I saw the scens/groups as objects yesterday in the Google Home app.
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
i'm on v 2.12.1.7 of the Home app, and still no scenes/groups are viewable (without going into Explore>Settings>Assistant>Home Control. annoying!
