Custom Device Status?
bulletcom
- Domoticz version: 4.10710
Hi - new user here so be gentle...!
I've got Domoticz running on my Pi3 with an RFXTRX433 transceiver and Visonic security sensors.
My question is - the default status for each sensor - Normal/Alarm - can these be edited anywhere? I'm unable to change the device type on the Switches page for these...
Ideally I'd like my door sensors to show 'Open/Closed' instead of 'Alarm/Normal'
Is this possible?
Thanks in advance,
David
Is this possible?
Thanks in advance,
David
bulletcom
Re: Custom Device Status?
Bump.
Anyone?
Anyone?
freijn
- Domoticz version: Stable
Goto the sensor and hit the middle button, not "log" not "Notifications but.. "change?" mine is in dutch "aanpassen"
Now change the switch type to door contact Voila..
bulletcom
Where? I don't have the 'Change' option on any of my RFX Visonic devices...
freijn
oohh mine is a switch... see screenshot.
- Capture.JPG (73.46 KiB) Viewed 1819 times
bulletcom
freijn
create a virtual switch and make it a contact switch ?
bulletcom
that's a possibility - but why do you get the change option and I don't? Are you using Visonic sensors?
freijn
sorry, I do not have those sensor, can't test it on my system
bulletcom
Ok. I"ve checked my other sensors and I have the change option so I think it must be related to the Visonic sensors.
Maybe Bert is around and can comment.
Thank you for your help - greetings from sunny England
bulletcom
I've emailed RFXCOM support -
Bert's replied: This is decoded with this text in Domoticz and if you want to change this please ask your question on the Domoticz forum.
Does anyone know how to edit the device status for a security device?
Thanks, David
Thanks, David
bulletcom
Bump (please!)
