Please help this noob! :D
OedzesG
Post by OedzesG »
Hallo everyone!
Sinds 2 weeks i install Domoticz and love it!
Now everything is connected, its time to make my first automation script.
Becouse i dont like blocky, i would love te use DzVents, but i think i only have some problems with understanding it :lol:
What i would like to do, is change the lights when my PLEX server starts to play.
So i usdes an PLEX script to send the data to my Domoticz en ceated some user-variables. this works perfect:
-1: Plex-server offline
0: Client inactief
1: video afspelen
2: gepauzeerde video
3: gestopt video
11: Audio afspelen
12: Onderbroken audio
13: gestopt audio
21: Foto weergeven
22: Onderbroken diavoorstelling
Now i created a small script in DzVents:
There are no errors at all! but script is not working.
Please help me understanding DzVents.
Thxx in advance!!!
freijn
Domoticz version: Stable
Re: Please help this noob! :D
Post by freijn »
perhaps start with some logging to see if the script is being hit?
logging = true
bla
bla
bla
if (logging) then print("script is Triggered " ) end
OedzesG
Post by OedzesG »
Thx for quick response!
Nothing happend in the log files:
So i thought maybe Dzvents is not working, but with the test script from WIKI:
How do you update the variable ?
You defined the variable as integer but you check if IT is equal to a string.
Please tag your code with code tags, makes it much easier to check.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
OedzesG
Post by OedzesG »
The variable is updated by Python script, bases on evenements happend in plex.
When i check this script with my uservariable is this correct.
But somehow i think that DzVents is not recognize: variables = {'PLEX STATUS [Chrome]'}
freijn
Post by freijn »
From: https://www.domoticz.com/wiki/DzVents:_ ... 7B_..._.7D
variables = { ... }
A list of one or more user variable-names as defined in Domoticz ( Setup > More options > User variables). If any of the variables listed here changes, the script is executed.
So ... is your variable defined there ?
OedzesG
Post by OedzesG »
Correct, thats why i write my script this way.
But somehow its not working, and it seems like this script is not hit.
And what happens if you update the variable manually?
OedzesG
Post by OedzesG »
Thnx!! that worked...
So it must be something in the script: Plex.py.
Ik wil search there!! thnx again!
OedzesG wrote: Tuesday 14 May 2019 12:31 So it must be something in the script: Plex.py.
Specific for this reason the dzVents method to update variables added an extra call to the eventSystem to trigger an event as the domoticz standard update way does not do this.
And please don't use jpg for displaying code or logs here. Use code tags
