Improve scaling of graphs.
Bochelork
Post by Bochelork »
My temperature history graph has a minimum of -6 degrees and a maximum of 43 degrees. The temperature scale goes from -60 to 60 degrees. So it's a range of 120 degrees while only 50 degrees is needed. Graphs are very flat this way. Maybe round the top and bottom to 10 degrees, so in my case let the scale go from -10 to 50 degrees.
Antori91
Domoticz version: 4.10717
Re: Improve scaling of graphs.
Post by Antori91 »
+1
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
JanAtHome
Domoticz version: 38153
Post by JanAtHome »
+1
Xztraz
Post by Xztraz »
i tried doing something abut this a couple of years ago but the framework for the graphs was a bit buggy and didn't allow for better combined ranges for temp and humidity ins the same graph. maybe the graph framework have been updated since then?
gizmocuz
Post by gizmocuz »
I think we can assign a min and max value to the graph like is done for the voltage graph for example...
gizmocuz
Post by gizmocuz »
Okey, seems this was done in the past...
We can configure the chart with some options:
alignTicks: false,
tickInterval: 0.5
This results in:
but now when enabling the Humidity the result is maybe a bit messy with the grid lines:
We can hide the gridlines always from the Humidity graph:
Without temp the humidity would then look like:
Whats preferred ? (ps. the 120% is still considered to be a bug in highchart...)
Xztraz
Post by Xztraz »
i think another option is to not show the grid lines for example humidity but stil show a scale for that. but then the lines will only align to temperature scale. i fighted with this before and then i considered readable scale lines as more important than 100%. but thats just my opinion among a lot of others regarding graphs. ;) maybe a bug report in their github would be best. i only reported in their forum
Xztraz
Post by Xztraz »
i see they have a bunch of bugs regarding autoscaling, ticks and so on and they don't seem high priority.
Antori91
Post by Antori91 »
I don't use very often graphs with Humidity value. Below are two examples with temperature only. To have usable graphs, the scale of the temperature graphs should be set (I think) accordingly to the min/max of the temperature. For example, for the "Temperature Last Year" graph below, the scale should be between 0°C and +30°C and not between -20°C and + 60°C.
Xztraz
Post by Xztraz »
same kind of bug regarding temperature scale in graph framework
Antori91
Post by Antori91 »
Is there any improvement regarding this issue using the latest release?
