Solution for bad connection Aeotic Z-wave stick v5 with Tkbhome tz78
tonbor
Two days of hard Work and so many attempts, raspberry 3b+, Aeotic, P1 and rfxcom at usb ports. Poorly reception z-wave. Tkbhome tz78 in garage would not connect to stick, distance 5 meters, two walls. Solution, put stick in usb hub with its own power, connect to raspberry and yes all connected
fargle
Re: Solution for bad connection Aeotic Z-wave stick v5 with Tkbhome tz78
28 metres from the controller behind a thick concrete wall NLOS.....another way to skin a cat.
If you can't go through, go over..
