wuffer wrote: Wednesday 09 January 2019 18:34
I got the iBox2 and FUT036. I can get it installed in domoticz and turn on and off but i cant change brightness. Any suggestions on whats wrong?
That is already more than I managed to get working with the FUT036
Could you describe your steps on how to get this working?
I just followed the domoticz wiki page
Could you elaborate a bit more?
What did you select? Bridge type? Type (RGBWW? or something else)?
What controller did you select in the app?
I have tried setting the ibox2 to v4/5 and 6 in domoticz and it doesn't matter if i use rgb, rgbww and what they are called.
I can only turn on and off the led strip. In the app i can change brightness. Its not possible for me to do that in domoticz
This is so weird. I updatet my rflink to newest firmware. Now its possible to change brightness but it's not normal. Around 50% brightness i'ts nearly as low as it can go but no mater if i choose brightnes higher or lower, then it gets brighter until i reach 0 or 100%.
Conclusion, 0 and 100% is the only place where it's correct.
The saturation option is not active in dZvents. Maybe a idea to test this with the guys behind dzvents.
@waaren can you do something with @Stuntteam and @dannybloe ?
RPi3 B+, Debain Stretch, Domoticz, Homebridge, Dashticz, RFLink, Milight, Z-Wave,Fibaro, Nanoleaf, Nest, Harmony Hub, Now try to understand pass2php
poudenes wrote: Saturday 27 April 2019 21:13
can you do a domoticz.devices(idx).dump() for this device and report back all relevant loglines? That might give enough information to work with.
I have a V6 bridge and a white led module with adjustable color temperature.
The mi-light app works perfect so the bridge is working
I can see in the log (domoticz) that the bridge is found and if i switch any button in domoticz (i've tried them al, rgbw, rgbww, ww) nothing happens.
The log says that a light has turned on or off.
What am i doiing wrong? Please help.
I'm a bit deseperate to control RGBWW/CCT with rflink
When I folow the C procedure of Rflink faq to pair and create RGBCCT light, domoticz create a RGBW subtype device.
For this RGBCCT products we need to use controls of the RGBWWZ subtype device.
So I've changed in SQL the subtype of this device directly in database, I've tried everything : RGB, RGBW, RGBWZ, RGBWW and RGBWWZ but no one can control correctly the RGBCCT milight bulb.
Color and ON/Off features are OK in all case, but dimming, saturation and temperature have heratics comportments or simply doesn't work.
It be a couple of months that I try to control RGBCCT in domoticz through rflink and even with the new domoticz version nothing works.
If devellopers need a beta tester I am OK for that, MP me.
Else, somebody knows how to control rflink with a dummy device to send commands like 10;MiLightv1;XXXXXX;04;0000;MODE4; ?
Many thanks.
Best regards.
NAS Syno, Last Stable Ver°
RFLink 433.92+NRF24L01 : 6 THN132N, 5 KIT_FP433TEMP / ++MiLights / ++DI-O
HarmonyHub : FreeRev, TV LG, Amp Sony
Cabasse StreamAmp100, 3 Awox StriimLightWifi
KLF200 : 5 Somfy IO
IFTTT : GoogleAgenda
Blockly, DzVents, Bash
Tasker
There is a post about might and a self.build hub to handle more then 65000 bulbs. They build a solid steady plugin as well. I'm using it now for almost a year the esp hub and since 2 weeks the plugin and it's so easy to use....
Baliku wrote: Saturday 18 May 2019 6:25
Hi everybody,
Many thanks.
Best regards.
Also never got rgb-ww / rgb-cct lights to get assigned the correct subtype in domoticz. Using the previously paired remote (fut092) the device gets added as rgbw and i can control the light's rgb leds but i can't control the warm/cold white leds. Did you find a solution?
I have the original WiFibox 2 and now have implemented also the Mi-Light gateway based on ESP8266.
It's working perfectly, very good project.
Mi-light has an official app you can install on your phone, which you can connect from the app to the WifiBox2 and controll the paring, select the zone, change colours etc.
It's supports multiple boxes, but when selecting search for the device, it does not find my new Mi-light gateway.
