RTS pulse width
433Mhz opensource Receiver & Transmitter.
mrefex
Domoticz version: 3.7041
RTS pulse width
Post by mrefex »
Is it possible to make the ON/OFF/STOP command shorter ?
I have some blinds with a tilt function and with domoticz it is not possible to put the blinds up or down.
This is because the ON or OFF command is to long while transmitting. thereby the blinds are tilting instead of going to the open or close position
emme
Domoticz version: latest
Re: RTS pulse width
Post by emme »
how you control them? (hardware)
I have fibato motor control that support UP/DOWN/STOP and the switch is configured as BLINDS with PERCENTAGE
then in the device config I can set up timers for lamellas and positioning
"We always done this way"
mrefex
Re: RTS pulse width
Post by mrefex »
RFLINK R46 ..i will try the percentage mode (never tried that)
emme
Re: RTS pulse width
Post by emme »
uh... sorry :( did not consider the area and post title :P )
mrefex
Re: RTS pulse width
Post by mrefex »
the percentage mode doesn't work..also i miss the STOP button which refers to the MY psoition of the blinds..i think it's a programming code in the RFLINK software on the adruino.
Stuntteam
Re: RTS pulse width
Post by Stuntteam »
We will look for a fix.. check pm
morilm
Target OS: OS X
Re: RTS pulse width
Post by morilm »
Hi all.
Any update on this? I have just installed a new blinds at home and the regular on/off only move the blinds a bit. This the one allowing the orientation.
Other sonfy blinds I have (normal blinds) works perfectly so this seems to be a new kind of protocol.
I'll be doing some logging and I'll send it to the rflink team to see if they can implemented it
whitecube
Domoticz version: 4.10603
Re: RTS pulse width
Post by whitecube »
mrefex wrote: Tuesday 02 May 2017 10:28 Is it possible to make the ON/OFF/STOP command shorter ?
i have exact the opposite problem :D with rflink r48 the command is to short. it moves a bit (little orientation) and stops. i need the command longer
