Is it possible to make the ON/OFF/STOP command shorter ?
I have some blinds with a tilt function and with domoticz it is not possible to put the blinds up or down.
This is because the ON or OFF command is to long while transmitting. thereby the blinds are tilting instead of going to the open or close position
RTS pulse width
- emme
- Domoticz version: latest
Re: RTS pulse width
how you control them? (hardware)
I have fibato motor control that support UP/DOWN/STOP and the switch is configured as BLINDS with PERCENTAGE
then in the device config I can set up timers for lamellas and positioning
"We always done this way"
- mrefex
- Domoticz version: 3.7041
Re: RTS pulse width
RFLINK R46 ..i will try the percentage mode (never tried that)
- emme
Re: RTS pulse width
uh... sorry
did not consider the area and post title
- mrefex
Re: RTS pulse width
the percentage mode doesn't work..also i miss the STOP button which refers to the MY psoition of the blinds..i think it's a programming code in the RFLINK software on the adruino.
- Stuntteam
Re: RTS pulse width
We will look for a fix.. check pm
Re: RTS pulse width
Hi all.
Any update on this? I have just installed a new blinds at home and the regular on/off only move the blinds a bit. This the one allowing the orientation.
Other sonfy blinds I have (normal blinds) works perfectly so this seems to be a new kind of protocol.
I'll be doing some logging and I'll send it to the rflink team to see if they can implemented it
- Target OS: -
- Domoticz version: 4.10603
Re: RTS pulse width
i have exact the opposite problemmrefex wrote: ↑Tuesday 02 May 2017 10:28 Is it possible to make the ON/OFF/STOP command shorter ?
