dzvents is using variables from other script
corthebor
Today I received a (Telegram) message "Sunscreen is going up" and this was sent by a script that nothing had to do with my sunscreen.
I found out that the script which turns on the lights should have sent the message "Lights going on" but used the message from the sunscreen-script .
the problem was the fact that I use the same line in both scripts:
os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..message..'" "https://api.telegram.org/bot'..token..'/sendMessage" ')
The variable: message is defined at the beginning of each script:
message = 'Sunscreen is going up' --> for the sunscreen-script
message = 'Lights going on' --> for the lamp-script
Does anyone know how to avoid this? besides that I have to rename all messages in the scripts with different names?
- waaren
Re: dzvents is using variables from other script
Best practice in programming is to limit the scope of variables as much as possible. In this case you could start with changing the declaration of these vars fromcorthebor wrote: Thursday 18 April 2019 21:05 Today I received a (Telegram) message "Sunscreen is going up" and this was sent by a script that nothing had to do with my sunscreen.
local message = 'Sunscreen is going up' --> for the sunscreen-script
local message = 'Lights going on' --> for the lamp-scriptDebian buster, bullseye on RPI-4, Intel NUC.
corthebor
@waaren
Thanks for the reply. I'll keep that in mind.
About domoticz.notify can natively send a notification to telegram: I looked in to that a while ago, but did not manage to get that working.
I will give it a try one of these days.
gr. Cor
gr. Cor
- waaren
in Domoticz [Setup] [Settings] [Notifications] in your dzVents script:corthebor wrote: Friday 19 April 2019 9:23 About domoticz.notify can natively send a notification to telegram: I looked in to that a while ago, but did not manage to get that working.
domoticz.notify("Subject", "message",domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)Debian buster, bullseye on RPI-4, Intel NUC.
corthebor
@waaren
corthebor
I managed to have the domoticz.notify command working but I changed back to the curl command because I received notifications on all configured services. (Email, pushover, telegram etc..).On a side note: domoticz.notify can natively send a notification to telegram since dzVents version 2.4.8
I better wait until the next (stable) update from domoticz to version 4.10200 (dzVents 2.4.8)
- waaren
That should not happen if you are on dzVents 2.4.8 and use the linecorthebor wrote: Saturday 20 April 2019 11:15I managed to have the domoticz.notify command working but I changed back to the curl command because I received notifications on all configured services. (Email, pushover, telegram etc..).On a side note: domoticz.notify can natively send a notification to telegram since dzVents version 2.4.8
corthebor
This is my stable version of domoticz and dzvents and there is no update available for now...
And I would rather not change to the beta version
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Version: 4.9700
- waaren
Understand. Can you try this in your current version ?corthebor wrote: Saturday 20 April 2019 11:51 This is my stable version of domoticz and dzvents and there is no update available for now...
Version: 4.9700
domoticz.notify("Subject", "message",domoticz.PRIORITY_NORMAL,nil,nil,"telegram")Debian buster, bullseye on RPI-4, Intel NUC.
corthebor
Ok, missed that.
Is working like it should be.
Thanks again
Thanks again
