Any one using one of these T+H sensors with RFLink?
433Mhz opensource Receiver & Transmitter.
Msmax
Domoticz version: V4.9700
Post by Msmax »
I just saw these on AliExpress and I like the shape with the LCD display.
Does any one here use one of these with Domoticz/RFLink?
mpx2
Domoticz version: 4.10717
Re: Any one using one of these T+H sensors with RFLink?
Post by mpx2 »
That sensor looks identical to Teldus Thermo/Hygro Sensor 433MHz
https://telldus.com/produkt/thermo-hygro-sensor-433mhz/
and SNDWAY GJ1096-00B
https://www.aliexpress.com/item/Outdoor ... 33608.html
mpx2
Post by mpx2 »
I bought for testing Telldus 313160. RFLink did recognize it but I cannot be sure it works 100% because there might be problems like with Biltema sensors.
whitecube
Domoticz version: 4.10603
Post by whitecube »
How long you had to wait that domoticz recognized the sensors?
i'm waiting some minutes but nothing (with rflink)
mpx2
Post by mpx2 »
whitecube wrote: Saturday 18 May 2019 22:56 How long you had to wait that domoticz recognized the sensors?
Looks like the update interwall is about 10 minutes.
Dave21w
Domoticz version: Stable
Post by Dave21w »
You can buy these from Amazon too, you get a pack of 2 for £17.99
https://www.amazon.co.uk/gp/product/B07 ... le_o03_s01
I have a few of them and they work just fine with my RFXCom and RFLink, they ID like this
5473 0 Temp + Humidity LCD Temp + Humidity WTGR800
mine seem to update every minute as you can see
2019-06-21 13:21:16.124 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:22:17.122 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:23:18.117 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:24:19.116 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:25:20.116 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:26:21.111 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:27:22.112 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
padrino
Domoticz version: N/A
Post by padrino »
Well,
it seems you cannot go just with the outer look of them... ;)
I bought these (in Germany) from "Renkforce"
With rflink they are recognized as FT007TH but they work not very reliable.
A lot of the time you get a perfect signal from them by every minute, but then, all of a sudden, it's minutes or hours till they are recognized again.
And you can see them transmitting because of the flashing led on the sensor. :(
So, don't buy just by the looks...
CU,
padrino
