I just saw these on AliExpress and I like the shape with the LCD display.
Does any one here use one of these with Domoticz/RFLink?
Any one using one of these T+H sensors with RFLink?
Msmax
- Domoticz version: V4.9700
- TempSensor_01b.jpg (125.1 KiB) Viewed 7759 times
- TempSensor_01a.jpg (63.8 KiB) Viewed 7759 times
mpx2
- Domoticz version: 4.10717
Re: Any one using one of these T+H sensors with RFLink?
That sensor looks identical to Teldus Thermo/Hygro Sensor 433MHz
https://telldus.com/produkt/thermo-hygro-sensor-433mhz/
and SNDWAY GJ1096-00B
https://www.aliexpress.com/item/Outdoor ... 33608.html
mpx2
I bought for testing Telldus 313160. RFLink did recognize it but I cannot be sure it works 100% because there might be problems like with Biltema sensors.
whitecube
- Target OS: -
- Domoticz version: 4.10603
How long you had to wait that domoticz recognized the sensors?
i'm waiting some minutes but nothing (with rflink)
mpx2
Looks like the update interwall is about 10 minutes.whitecube wrote: Saturday 18 May 2019 22:56 How long you had to wait that domoticz recognized the sensors?
Dave21w
- Domoticz version: Stable
You can buy these from Amazon too, you get a pack of 2 for £17.99
https://www.amazon.co.uk/gp/product/B07 ... le_o03_s01
I have a few of them and they work just fine with my RFXCom and RFLink, they ID like this
5473 0 Temp + Humidity LCD Temp + Humidity WTGR800
mine seem to update every minute as you can see
2019-06-21 13:21:16.124 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:22:17.122 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:23:18.117 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:24:19.116 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:25:20.116 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:26:21.111 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
2019-06-21 13:27:22.112 (RFLink USB) Temp + Humidity (Temp + Humidity LCD)
Well,
it seems you cannot go just with the outer look of them...
I bought these (in Germany) from "Renkforce"
With rflink they are recognized as FT007TH but they work not very reliable.
A lot of the time you get a perfect signal from them by every minute, but then, all of a sudden, it's minutes or hours till they are recognized again.
And you can see them transmitting because of the flashing led on the sensor.
So, don't buy just by the looks...
CU,
padrino
CU,
padrino
