Python Plugin: Domoticz-Google-Plugin
I'm trying to send a message to my Google Home Mini device. Up untill now without succces. I get a timeout.
(Google Home) [Google Home - Huiskamer Volume] Update 2(2):'50'(40): 0(0)
2019-03-26 07:13:38.884 (Google Home) [Google Home - Huiskamer Volume] Update 0(2):'50'(50): 0(0)
2019-03-26 07:13:38.104 Status: User: Admin initiated a switch command (11/Raamlamp/On)
2019-03-26 07:13:38.476 Status: Notification: This is a test message
2019-03-26 07:13:48.731 (Google Home) [Google Home - Huiskamer Volume] Update 0(0):'40'(50): 0(0)
2019-03-26 07:13:48.787 (Google Home) [Google Home - Huiskamer Volume] Update 2(0):'40'(40): 0(0)
2019-03-26 07:13:48.722 Error: (Google Home) Notification 'This is a test message', sent to 'Huiskamer' timed out
I'm not sure in what to fill in for the Voice message IP address. Is this the 192.168.etc with port number like 8080? Do I need to forward a port to my Pi?
Thanks for any suggestions!
Kind regards, Rob
Kind regards, Rob
- Dnpwwo
Re: Python Plugin: Domoticz-Google-Plugin
@schulpr,
Good news ! No need for nasty IP & port numbers !
That parameters accepts the Google device's 'friendly name'. This is the name that you gave the device during it's initial configuration or, if you created a device group, the group name.
To make sure you get it right, open the Google Home app on your phone and use the device name as shown.
Hi Dnpwwo,
Are we talking about the same parameter, the "Voice message IP address"?
In "Voice Device/Group" I have the name of my Mini, "Huiskamer".
Kind regards, Rob
Kind regards, Rob
- Domoticz version: 3.7243
Let someone write step by step how to send a message to my google mini speaker
- Dnpwwo
@schulpr,
My bad. You are correct the "Voice message IP address" is the IP address of the computer your Domoticz instance is running on (probably is 192.168.x.x).
The port should NOT be 8080. It needs to be one that is not in use, try the default.
If you are on a normal home network there should be no need for port forwarding
There is a new version from tonight (1.13.1) that may resolve the time out error message
- Domoticz version: 2020.2
I made this video: https://youtu.be/bC3HEBhbp0k i hope that answers your questionkniazio wrote:Let someone write step by step how to send a message to my google mini speaker
Verstuurd vanaf mijn SM-G975F met Tapatalk
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
@Dnpwwo,
It's working fine now. Thanks!
Regards, Rob
Regards, Rob
I do not have Chromecast for Google Home mini onlysnellejellep wrote: ↑Wednesday 27 March 2019 11:25I made this video: https://youtu.be/bC3HEBhbp0k i hope that answers your questionkniazio wrote:Let someone write step by step how to send a message to my google mini speaker
How do I send a message to Google Home Mini?
You can put in the name of the google home mini and it should work
Where should I enter it?snellejellep wrote: ↑Wednesday 27 March 2019 13:38 You can put in the name of the google home mini and it should work
Under hardware, see picture
After the last update, I have something like this in the logs:
Error: (Google Home) 'gtts' module import error: No module named 'gtts': Voice notifications will not be enabled
Hi, there has been a major change in the plugin. You need to install gtts. See the readme on github..it says in fetail what's needed. You also need to manually create the directory "messages" in the plugin directory.
Succes, Hans
Succes, Hans
During installation of gtts, there were such errors:
The previous error still occurs
Collecting beautifulsoup4 (from bs4->gtts)
Exception:
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 391, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 387, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
response.begin()
File "/usr/lib/python3.5/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.5/http/client.py", line 266, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 353, in run
wb.build(autobuilding=True)
File "/usr/lib/python3/dist-packages/pip/wheel.py", line 749, in build
self.requirement_set.prepare_files(self.finder)
File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 554, in _prepare_file
require_hashes
File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File "/usr/lib/python3/dist-packages/pip/index.py", line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File "/usr/lib/python3/dist-packages/pip/index.py", line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File "/usr/lib/python3/dist-packages/pip/index.py", line 568, in _get_pages
page = self._get_page(location)
File "/usr/lib/python3/dist-packages/pip/index.py", line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File "/usr/lib/python3/dist-packages/pip/index.py", line 792, in get_page
"Cache-Control": "max-age=600",
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
return self.request('GET', url, **kwargs)
File "/usr/lib/python3/dist-packages/pip/download.py", line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
timeout=timeout
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
2019-04-10 21:37:19.928 Error: (Google Home) 'gtts' module import error: No module named 'gtts': Voice notifications will not be enabled
It's OK. I installed gtts again by sudo
- heggink
- Domoticz version: 12451
Any idea how to resolve
The plugin starts fine, then shows this error and no devices are created.discoveryCallback: 'Chromecast' object has no attribute 'start'
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- heggink
nvm, needed to read the forum first and then update pychromecast. Sorry.
DASHTICZ 🙃
DASHTICZ 🙃
I can't get my notifications working. The Home mini activates when notifications is send, adjusting volume and plays a short announce melody, that's all. No text.
I use
commandArray['Google - Spiller'] = "SendNotification God morgen"
After 60 sec. I got
Error: (Google høytaler) Notification sent to 'Stue google' timed out
I use
After 60 sec. I got
I have the same
- Domoticz version: Beta 4.1
The text widget is not updated anymore with info on the track that is playing. The rest works great.
Running domo 4.1063 and python 3.5.3
Tried with TuneIn, youtube and Poweramp. Status remains 0 or none.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
