Python Plugin: Domoticz-Google-Plugin
schulpr
Post by schulpr »
I'm trying to send a message to my Google Home Mini device. Up untill now without succces. I get a timeout.
(Google Home) [Google Home - Huiskamer Volume] Update 2(2):'50'(40): 0(0)
2019-03-26 07:13:38.884 (Google Home) [Google Home - Huiskamer Volume] Update 0(2):'50'(50): 0(0)
2019-03-26 07:13:38.104 Status: User: Admin initiated a switch command (11/Raamlamp/On)
2019-03-26 07:13:38.476 Status: Notification: This is a test message
2019-03-26 07:13:48.731 (Google Home) [Google Home - Huiskamer Volume] Update 0(0):'40'(50): 0(0)
2019-03-26 07:13:48.787 (Google Home) [Google Home - Huiskamer Volume] Update 2(0):'40'(40): 0(0)
2019-03-26 07:13:48.722 Error: (Google Home) Notification 'This is a test message', sent to 'Huiskamer' timed out
I'm not sure in what to fill in for the Voice message IP address. Is this the 192.168.etc with port number like 8080? Do I need to forward a port to my Pi?
Thanks for any suggestions!
Kind regards, Rob
Dnpwwo
Re: Python Plugin: Domoticz-Google-Plugin
Post by Dnpwwo »
@schulpr,
Good news ! No need for nasty IP & port numbers !
That parameters accepts the Google device's 'friendly name'. This is the name that you gave the device during it's initial configuration or, if you created a device group, the group name.
To make sure you get it right, open the Google Home app on your phone and use the device name as shown.
schulpr
Post by schulpr »
Hi Dnpwwo,
Are we talking about the same parameter, the "Voice message IP address"?
In "Voice Device/Group" I have the name of my Mini, "Huiskamer".
Kind regards, Rob
kniazio
Domoticz version: 3.7243
Post by kniazio »
Let someone write step by step how to send a message to my google mini speaker
Dnpwwo
Post by Dnpwwo »
@schulpr,
My bad. You are correct the "Voice message IP address" is the IP address of the computer your Domoticz instance is running on (probably is 192.168.x.x).
The port should NOT be 8080. It needs to be one that is not in use, try the default.
If you are on a normal home network there should be no need for port forwarding
There is a new version from tonight (1.13.1) that may resolve the time out error message
snellejellep
Post by snellejellep »
kniazio wrote:Let someone write step by step how to send a message to my google mini speaker
I made this video: https://youtu.be/bC3HEBhbp0k i hope that answers your question
Verstuurd vanaf mijn SM-G975F met Tapatalk
schulpr
Post by schulpr »
@Dnpwwo,
It's working fine now. Thanks!
Regards, Rob
kniazio
Post by kniazio »
snellejellep wrote: Wednesday 27 March 2019 11:25
I do not have Chromecast for Google Home mini only
How do I send a message to Google Home Mini?
snellejellep
You can put in the name of the google home mini and it should work
kniazio
Post by kniazio »
snellejellep wrote: Wednesday 27 March 2019 13:38 You can put in the name of the google home mini and it should work
Where should I enter it?
snellejellep
Under hardware, see pictureImage
kniazio
Post by kniazio »
After the last update, I have something like this in the logs:
 Error: (Google Home) 'gtts' module import error: No module named 'gtts': Voice notifications will not be enabled
DutchHans
Post by DutchHans »
Hi, there has been a major change in the plugin. You need to install gtts. See the readme on github..it says in fetail what's needed. You also need to manually create the directory "messages" in the plugin directory.
Succes, Hans
kniazio
Post by kniazio »
During installation of gtts, there were such errors:
Collecting beautifulsoup4 (from bs4->gtts)
Exception:
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
    chunked=chunked)
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 391, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 387, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
    response.begin()
  File "/usr/lib/python3.5/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.5/http/client.py", line 266, in _read_status
    raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 353, in run
    wb.build(autobuilding=True)
  File "/usr/lib/python3/dist-packages/pip/wheel.py", line 749, in build
    self.requirement_set.prepare_files(self.finder)
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 554, in _prepare_file
    require_hashes
  File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 278, in populate_link
    self.link = finder.find_requirement(self, upgrade)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 465, in find_requirement
    all_candidates = self.find_all_candidates(req.name)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 423, in find_all_candidates
    for page in self._get_pages(url_locations, project_name):
  File "/usr/lib/python3/dist-packages/pip/index.py", line 568, in _get_pages
    page = self._get_page(location)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 683, in _get_page
    return HTMLPage.get_page(link, session=self.session)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 792, in get_page
    "Cache-Control": "max-age=600",
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
    return self.request('GET', url, **kwargs)
  File "/usr/lib/python3/dist-packages/pip/download.py", line 386, in request
    return super(PipSession, self).request(method, url, *args, **kwargs)
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
    r = adapter.send(request, **kwargs)
  File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
    resp = super(CacheControlAdapter, self).send(request, **kw)
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
    timeout=timeout
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
    total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
The previous error still occurs
2019-04-10 21:37:19.928 Error: (Google Home) 'gtts' module import error: No module named 'gtts': Voice notifications will not be enabled
kniazio
Post by kniazio »
It's OK. I installed gtts again by sudo
heggink
Domoticz version: 12451
Post by heggink »
Any idea how to resolve
discoveryCallback: 'Chromecast' object has no attribute 'start'
The plugin starts fine, then shows this error and no devices are created.
DASHTICZ 🙃
P1 meter & solar panel
heggink
Post by heggink »
nvm, needed to read the forum first and then update pychromecast. Sorry.
DASHTICZ 🙃
deve87
Post by deve87 »
I can't get my notifications working. The Home mini activates when notifications is send, adjusting volume and plays a short announce melody, that's all. No text.
I use
commandArray['Google - Spiller'] = "SendNotification God morgen"
After 60 sec. I got
Error: (Google høytaler) Notification sent to 'Stue google' timed out
kniazio
Post by kniazio »
I have the same
gerbenvanasselt
Domoticz version: Beta 4.1
Post by gerbenvanasselt »
The text widget is not updated anymore with info on the track that is playing. The rest works great.
Running domo 4.1063 and python 3.5.3
Tried with TuneIn, youtube and Poweramp. Status remains 0 or none.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
