Switches not showing up when accessing from other PC
JonasDHollander
Post by JonasDHollander »
Hello everybody,
I have setup Domoticz on a small Windows 10 PC, and added a switch (RFX USB 433 - controlled)
I then installed Dashticz in the folder domoticz/www/Dashticz
My config seems to work on the local system,
but when i access my Dashticz from another pc in the network, i get the same Dashboard without the switch...
It also returns an error 'new version is available', while my installation is a day old. So i think that's not possible.
Any ideas what causes this?
stlaha2007
Re: Switches not showing up when accessing from other PC
Post by stlaha2007 »
Hey there,
Asume your on the normal/master branch, ignore the 'new version message'. Have that also on one of my dashticz instances.
To be sure your accessing it the right way, what are the config-lines to your domoticz-site. Maybe better to drop your CONFIG.js here ;-).
According to your writing your using the webserver 'within' domoticz. But how do you access it? Perhaps post the urls which works and which doesn't?
It clarifies a bit more, and where are better able to help.
Regards,
Stephan
