Hello everybody,
I have setup Domoticz on a small Windows 10 PC, and added a switch (RFX USB 433 - controlled)
I then installed Dashticz in the folder domoticz/www/Dashticz
My config seems to work on the local system,
but when i access my Dashticz from another pc in the network, i get the same Dashboard without the switch...
It also returns an error 'new version is available', while my installation is a day old. So i think that's not possible.
Any ideas what causes this?
Switches not showing up when accessing from other PC
JonasDHollander
stlaha2007
- Target OS: -
Re: Switches not showing up when accessing from other PC
Hey there,
Asume your on the normal/master branch, ignore the 'new version message'. Have that also on one of my dashticz instances.
To be sure your accessing it the right way, what are the config-lines to your domoticz-site. Maybe better to drop your CONFIG.js here
According to your writing your using the webserver 'within' domoticz. But how do you access it? Perhaps post the urls which works and which doesn't?
It clarifies a bit more, and where are better able to help.
Regards,
Stephan
Regards,
Stephan
