Show floorplan in Dashticz?
JonasDHollander
Post by JonasDHollander »
Hello everybody,
I am trying to find out if it is possible to add a floorplan in Dashticz.
Is there an easy way to switch to a floorplan view in the Dashticz UI?
Or do i have to be creative and switch tabs in IE? (I am running on a windows machine, tablet browses to Domoticz/Dashticz)
pvm
Domoticz version: 4.10538
Re: Show floorplan in Dashticz?
Post by pvm »
You can switch to another screen when a device changes state, de the wiki.
Maybe you can show the Floorplan in an iframe??
Lokonli
Post by Lokonli »
Some example code below.
The first button will open a popup window with the Domoticz floorplan.
The second button will slide to the second screen.
The second screen contains the Domoticz floorplan in a frame.
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'http://192.168.178.18:8080';
config['auto_swipe_back_after'] = '0';
//Definition of blocks
blocks = {}
//button configuration
buttons = {}
buttons.floorplan = {
  width:12,
  title:'Floor plan',
  url: 'http://192.168.178.18:8080/#Floorplans'
buttons.slidefloorplan = {
  width: 12,
  title:"slide to floorplan",
  slide:2
////////////////////// FRAMES ///////////////////////////
var frames = {}
frames.floorplan = {
  frameurl:"http://192.168.178.18:8080/#/Floorplans",
  height: '600',
  width:12
//Definition of columns
columns = {}
columns[1] = {
    blocks: [buttons.floorplan, buttons.slidefloorplan],
    width: 2
columns[2] = {
    blocks: [frames.floorplan],
    width: 12
//Definition of screens
screens = {}
screens[1] = {
  columns: [1]
screens[2] = {
  columns: [2]
JonasDHollander
Thank you for the advice! Will try this out asap!
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
Is it possible to show only the second floorplan if you have multiple plans ?
Also is it possible to show only the floorplan without the Domoticz webmenu ?
poweredge
Post by poweredge »
same here - curious if this is possible ...
DM2021.1 (pri+sec) VM/RPI4. Dashticz @touchscreen. IT: Dell ESXi cluster, UPS, fiber+4g WAN. Smart: Aeotec/Neo/Qubino/Eurotronic zwave, Philips Hue, P1, rfxom433, OTGW, ITHO WiFi, Shelly shutter/water sens, NEST v3, 9x Alexa
jacobsentertainment
Domoticz version: 2021-1
Post by jacobsentertainment »
Seems there is no solution to this topic.
voyo
Post by voyo »
bump? :D
Same questions from me, how to make floorplans more robust in Dashticz
