PiZiGate and Aqara wireless switch
ronaldbro
- Domoticz version: 2020.2
Got my PiZiGate today and was successfully able to add an Aqara door sensor, power plug and climate sensor.
But when I try to add the wireless switch (the little square one with one round button) I get the following error in the log: Not able to get all needed attributes on time
Any suggestions would be very welcome
Thanks,
Ronald
Thanks,
Ronald
fredo
Re: PiZiGate and Aqara wireless switch
DId you tried several time ? Was the zigate still in pairing mode ?
ronaldbro
Yep, I tried about 20 times and stil in pairing mode. Log is the same every time:
2019-03-28 23:49:34.367 Status: (Zigate) Leave indication from IEEE: 00158d00021311e6 , Status: 00
2019-03-28 23:49:35.837 Status: (Zigate) Device Annoucement ShortAddr: 6c2c, IEEE: 00158d00021311e6
2019-03-28 23:49:36.866 Status: (Zigate) [-] NEW OBJECT: 6c2c Request Simple Descriptor for Ep: 01
2019-03-28 23:49:38.529 Status: (Zigate) [0] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:41.282 Status: (Zigate) [-] NEW OBJECT: 6c2c Simple Descriptor EP 01
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c ProfileID 0104
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c ZDeviceID 0103
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster IN Count: 03
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster In 1: 0000
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster In 2: 0012
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster In 3: 0003
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster OUT Count: 01
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster Out 1: 0000
2019-03-28 23:49:43.550 Status: (Zigate) [0] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:48.541 Status: (Zigate) [1] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:53.558 Status: (Zigate) [2] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:53.559 Status: (Zigate) [2] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:53.563 Status: (Zigate) [2] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:58.550 Status: (Zigate) [3] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:58.553 Status: (Zigate) [3] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:50:03.540 Status: (Zigate) [4] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:50:03.540 Status: (Zigate) [4] NEW OBJECT: 6c2c Not able to get all needed attributes on time
ronaldbro
No problem with all other devices. I have successfully connected:
6 Aqara TempHumBaro sensors
11 Aqara door sensors
2 Aqara motion detectors
3 Aqara water detectors
2 Tradfri bulbs
1 Hue bulb
2 Tradfri bulbs
1 Hue bulb
fredo
I suspect this is a new Xiaomi model and seems not recognized by the plugin. You can check in the file DeviceConf.txt if you find an entry 'lumi.remote.b1acn01'ronaldbro wrote: Thursday 28 March 2019 23:52 Yep, I tried about 20 times and stil in pairing mode. Log is the same every time:
ronaldbro
Thanks,
Can I just add the line to DeviceConf or should I wait for the next release?
fredo
I believe you can add the line.
Or may be better is to replace your existing one, by the recommended patch .
https://raw.githubusercontent.com/sasu- ... ceConf.txt
It might be good to do some backup before in case it breaks something
ronaldbro
Thanks, this worked. I was able to add the button.
Unfortunatly the button only works partly with Zigate. Only single click and double click work. According to the zigate docs there should also be a tripple click and 4 click, but that doesn't work. I think the device doesn't support this.
The button also supports long press and long press release, but I guess this is not supported by Zigate.
ronaldbro
Is there any place where I can make a change request?
fredo
Is the device on Domoticz correctly created ? Means you have a Switch selector with Click 1, 2, 3 and 4 ?
==> If that is the case, the creation is correctly done, and the patch you did work.
==> If that is not the case, this mean , something is wrong in the device creation and so the patch is not good.
You might want to put some Logs to see exactly what is happening.
ronaldbro
Yes, this is the case. Thats the good part
But when I do a single click on the button I get an event, same with double click. But with a tripple click or 4 click nothing happens.
And I really miss the long press...
fredo
As said, if you could post the log when you are pressing once, twice, long press ...., this would be more helpfull.
fredo
Thanks for such detailed Logs.
Here after is what I have been able to identify.
In short:
4 clicks and 3 clicks do not report anything. At least the Hardware Zigate doesn't send anything to the plugin.
Long press - is reported to domoticz with Level 20 (should be 3 Click)
2 Click - is reported to domoticz with Level 10 (should be 2 click)
1 click - is reported to domoticz with Level 00 (should be 1 click)
At least this is my interpretation as I do not have such device. May be someone with that device should comment it ?
In short:
Long press
2019-03-31 12:48:09.629 (Zigate) decodeAttribute( 21, 0000)
2019-03-31 12:48:09.629 (Zigate) ReadCluster - ClusterId=0012 - Switch Aqara: EP: 01 Value: 0
2019-03-31 12:48:09.630 (Zigate) MajDomoDevice - Device ID : 00158d00021311e6 - Device EP : 01 - Type : 0006 - Value : 3 - Hue : - Attribute_ :
Update Device 3:20
4 Clicks
=> Nothing coming from device
3 Clicks
==> Nothing coming from device
2 Clicks
2019-03-31 12:43:26.586 (Zigate) ZigateRead - decoded data : 018102000f8c1ccc150100120055002100020002a203 lenght : 44
2019-03-31 12:43:26.587 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 8c, Data: 1ccc150100120055002100020002; RSSI: a2
2019-03-31 12:43:26.587 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000f8c1ccc150100120055002100020002a203
2019-03-31 12:43:26.587 (Zigate) Decode8102 - Individual Attribute response : [cc15:01] ClusterID: 0012 AttributeID: 0055 Status: 00 Type: 21 Size: 0002 ClusterData: >0002<
2019-03-31 12:43:26.587 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:43:26.587 (Zigate) Decode8102 : Attribute Report from cc15 SQN = 1c ClusterID = 0012 AttrID = 0055 Attribute Data = 0002
Update Device 2:10
1 Click
2019-03-31 12:41:44.805 (Zigate) ZigateRead - decoded data : 018102000f881bcc150100120055002100020001a203 lenght : 44
2019-03-31 12:41:44.805 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 88, Data: 1bcc150100120055002100020001; RSSI: a2
2019-03-31 12:41:44.805 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000f881bcc150100120055002100020001a203
2019-03-31 12:41:44.806 (Zigate) Decode8102 - Individual Attribute response : [cc15:01] ClusterID: 0012 AttributeID: 0055 Status: 00 Type: 21 Size: 0002 ClusterData: >0001<
Update Device 1:00-
fredo
What do you mean According to the Zigate docs ?According to the zigate docs there should also be a tripple click and 4 click, but that doesn't work. I think the device doesn't support this.
ronaldbro
I mean this:fredo wrote: Sunday 31 March 2019 17:33What do you mean According to the Zigate docs ?According to the zigate docs there should also be a tripple click and 4 click, but that doesn't work. I think the device doesn't support this.
https://github.com/pipiche38/Domoticz-Z ... Devices.md
I will check the long press again, maybe it’s just a textual mistake
ronaldbro
I did some tests and I can confirm that a long press sets level 20 and when pressing the event is send every few seconds repeatively.
So the only events that I get from the device is single click, double click and long press.
enough for me, so I'm happy
Thanks for your help.
If you want me to test something please let me know. I would be happy to.
ronaldbro
I did some more testing and I noticed that after a long press (level 20) I get a single click on the release of the button. This should have been a long press release.
- Spoiler: show
ronaldbro
just a small update, the single click message after a long press does not happen always. looks like a timing issue. when I press the button for 3 seconds I get a level 20 update without a level 0 after. When I press it for 5 seconds I get a level 20 and a level 0 after.
