End of Weather Underground [Solved] Topic is solved
- Domoticz version: mixed
Re: End of Weather Underground
As usual with software updates/upgrades:
it takes some time & effort before you get rid of the glitches.
100% Maturity & Testing prior to release is hardly possible, and even then 'in the field' some application may occur not foreseen beforehand .......
Let's just wait to be surprised.
- LouiS22
FYI, the built in WU is working again, but you have to replace your current API key to a new one, also you have to remove the pws: and use only the station's name (in my case it's IBUDAPES25).
- Domoticz version: 3.5877
Damn, my good old key that was still working, is now giving
The end of an era
"Error: WUnderground: Error: this key does not exist"
For me it does not work.
Always :
2019-03-28 11:35:10.941 Error: WUnderground: Error: this key does not exist
Good work!
Clear hint how to restart.
Under version V4.10573 of Domoticz I now see all widgets for WUnderground again coming alive, except for Visibility.
As I mentioned: expect some glitches ......
- Domoticz version: 4.10076
For now I have to own a PWS to get a API Key? Is that right?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
yesFor now I have to own a PWS to get a API Key? Is that right?
- LouiS22
Yup, visibility is the only one not working so far.Toulon7559 wrote: ↑Thursday 28 March 2019 11:41 Good work!
How to install the V4.10573?
- FireWizard
Go to Setup; Choose Settings.
Under the first Tab "System", you will find: "Software Updates:"
Select as Release Channel "Beta".
The latest published release is V 4.10577
ThanksFireWizard wrote: ↑Thursday 28 March 2019 15:52 Go to Setup; Choose Settings.
Updated to the Beta, Weather Underground sort of works again with my PWS and new API
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC with Node-Red and MQTT / SolarEdge SE3500H modbus_tcp / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Yess, it works, thanks.
- Westcott
Odd, it doesn't work for me, on v 4.10601.
Error: Wunderground: Error getting http data! (Check API key!)
The key is correct, an HTTP call direct works correctly
https://api.weather.com/v2/pws/observat ... iKey=MYKEY
With version Version: 4.10597 (beta) no more problems
Hi, it seems to work (Domoticz version 4.9700 - beta) but something is wrong with the wind. I'm using the km/h unit but Domoticz show much more than Wunderground: 50 km/h (in Domoticz) instead of 14 km/h (real speed shown on Wunderground), I guess somewhere there is a unit mismatch.
- Domoticz version: v3.8975
I have the same problem.Westcott wrote: ↑Sunday 07 April 2019 21:54 Odd, it doesn't work for me, on v 4.10601.
https://api.weather.com/v2/pws/observations/current?stationId=ILONDON702&format=json&units=m&apiKey=[KEY]
from the command line, it says " Missing apiKey, generated error".
Any ideas please?
Since last week (2019 June 6th) the WU sensors aren't update anymore in my domoticz.
I get the same error message as mentioned above.
Before it was still working as expected so i assume something changed recently
When i look at the url that's used in the domoticz code (just before the error that is thrown) I see v2 of the api and in a lot of other places in the code it is allready changed to v3
sURL << "https://api.weather.com/v2/pws/observat ... stationId=" << szLoc << "&format=json&units=m&apiKey=" << m_APIKey;
bool bret;
std::string szURL=sURL.str();
bret=HTTPClient::GET(szURL,sResult);
if (!bret)
_log.Log(LOG_ERROR,"Wunderground: Error getting http data! (Check API key!)");
return;
I assume v2 isn't supported anymore (by wunderground) and we should use v3 also in this place.
I think we should use next url
sURL << "https://api.weather.com/v3/location/poi ... US&apiKey=" << m_APIKey <<"&pws=" << szLoc << "&format=json"
This url works in the browser (i see some json result, btw v2 url as used in the current code doesn't give any results at all)
I don't know how to change this myself. Is there somebody who could have a look at it?
Thanks in advance!!
bool bret;
if (!bret)
return;
Thanks in advance!!
with some help of gizmocuz (thanks !!!) i solved the issue i described above
the stationid that i used in my settings was no longer available.
the error that mentioned the api key was incorrect pointed me in the wrong direction
after changing the stationif it worked again.
