it takes some time & effort before you get rid of the glitches.
100% Maturity & Testing prior to release is hardly possible, and even then 'in the field' some application may occur not foreseen beforehand .......
"Error: WUnderground: Error: this key does not exist"For me it does not work.LouiS22 wrote: Thursday 28 March 2019 9:57 FYI, the built in WU is working again, but you have to replace your current API key to a new one, also you have to remove the pws: and use only the station's name (in my case it's IBUDAPES25).
2019-03-28 11:35:10.941 Error: WUnderground: Error: this key does not existyesFor now I have to own a PWS to get a API Key? Is that right?
Yup, visibility is the only one not working so far.Toulon7559 wrote: Thursday 28 March 2019 11:41Good work!
Clear hint how to restart.
Under version V4.10573 of Domoticz I now see all widgets for WUnderground again coming alive, except for Visibility.
As I mentioned: expect some glitches ......
Switch to beta channel, then you'll have the latest version.
ThanksFireWizard wrote: Thursday 28 March 2019 15:52 Go to Setup; Choose Settings.
Under the first Tab "System", you will find: "Software Updates:"
Select as Release Channel "Beta".
The latest published release is V 4.10577
I have the same problem.Westcott wrote: Sunday 07 April 2019 21:54 Odd, it doesn't work for me, on v 4.10601.
Error: Wunderground: Error getting http data! (Check API key!)
The key is correct, an HTTP call direct works correctly
https://api.weather.com/v2/pws/observat ... iKey=MYKEY
https://api.weather.com/v2/pws/observations/current?stationId=ILONDON702&format=json&units=m&apiKey=[KEY]
