H801 RGB
credens
H801 RGB
Post by credens »
Hi!
I have a rgb h801 driver and when I add the switch in Dashticz v2.5.8 I do not see the selector color only the brightness control. Why? Setting config ['no_rgb'] = 0.
Lokonli
Re: H801 RGB
Post by Lokonli »
credens wrote: Sunday 10 March 2019 19:31 Hi!
Can you post the results of:
http://<domoticz ip>:<port>/json.htm?type=devices&rid=123
Replace 123 with the domoticz device id of your rgb h801 device.
credens
Re: H801 RGB
Post by credens »
   "ActTime" : 1552279683,
   "AstrTwilightEnd" : "19:22",
   "AstrTwilightStart" : "03:60",
   "CivTwilightEnd" : "18:01",
   "CivTwilightStart" : "05:21",
   "DayLength" : "11:32",
   "NautTwilightEnd" : "18:41",
   "NautTwilightStart" : "04:41",
   "ServerTime" : "2019-03-11 05:48:03",
   "SunAtSouth" : "11:05",
   "Sunrise" : "05:55",
   "Sunset" : "17:27",
   "app_version" : "4.9700",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "Color" : "{\"b\":242,\"cw\":0,\"g\":255,\"m\":3,\"r\":224,\"t\":0,\"ww\":0}",
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "DimmerType" : "abs",
         "Favorite" : 1,
         "HardwareID" : 4,
         "HardwareName" : "Diody kolorowe",
         "HardwareType" : "H801 LED WiFi Controller with Tasmota firmware",
         "HardwareTypeVal" : 94,
         "HaveDimmer" : true,
         "HaveGroupCmd" : false,
         "HaveTimeout" : false,
         "ID" : "00040001",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2019-03-10 18:43:15",
         "Level" : 100,
         "LevelInt" : 100,
         "MaxDimLevel" : 100,
         "Name" : "Diody kolorowe - RGB",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "RGB",
         "SwitchType" : "Dimmer",
         "SwitchTypeVal" : 7,
         "Timers" : "false",
         "Type" : "Color Switch",
         "TypeImg" : "dimmer",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "6"
   "status" : "OK",
   "title" : "Devices"
Lokonli
Re: H801 RGB
Post by Lokonli »
credens wrote: Monday 11 March 2019 5:50
   "Sunset" : "17:27",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 4,
         "ID" : "00040001",
         "Image" : "Light",
         "Level" : 100,
         "LevelInt" : 100,
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "RGB",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "6"
   "status" : "OK",
   "title" : "Devices"
Your device has subtype RGB. Diving into the Dashticz code it seems Dashticz currently only recognizes RGBW and RGBWW devices.
I'll contact you via PM probably tonight for some additional testing.
credens
Re: H801 RGB
Post by credens »
When I change the device sub-type to rgbw, the color selector does not appear either.
Then in
"SubType" : "RGBWZ"
Also as I create a virtual RGB or RGBW switch unrelated to H801, there is also no color selector in dashticz.
Lokonli
Re: H801 RGB
Post by Lokonli »
Lokonli wrote: Monday 11 March 2019 12:27
   "Sunset" : "17:27",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 4,
         "ID" : "00040001",
         "Image" : "Light",
         "Level" : 100,
         "LevelInt" : 100,
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "RGB",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "6"
   "status" : "OK",
   "title" : "Devices"
Fix will be merged in the next beta.
robgeerts
Domoticz version: 3.7067
Re: H801 RGB
Post by robgeerts »
Lokonli wrote: Monday 11 March 2019 21:22
   "Sunset" : "17:27",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 4,
         "ID" : "00040001",
         "Image" : "Light",
         "Level" : 100,
         "LevelInt" : 100,
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "RGB",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "6"
   "status" : "OK",
   "title" : "Devices"
Available in beta now :)
Users browsing this forum: Bing [Bot] and 0 guests
