H801 RGB
Lokonli
Re: H801 RGB
Can you post the results of:credens wrote: Sunday 10 March 2019 19:31 Hi!
I have a rgb h801 driver and when I add the switch in Dashticz v2.5.8 I do not see the selector color only the brightness control. Why? Setting config ['no_rgb'] = 0.
http://<domoticz ip>:<port>/json.htm?type=devices&rid=123-
credens
Re: H801 RGB
"ActTime" : 1552279683,
"AstrTwilightEnd" : "19:22",
"AstrTwilightStart" : "03:60",
"CivTwilightEnd" : "18:01",
"CivTwilightStart" : "05:21",
"DayLength" : "11:32",
"NautTwilightEnd" : "18:41",
"NautTwilightStart" : "04:41",
"ServerTime" : "2019-03-11 05:48:03",
"SunAtSouth" : "11:05",
"Sunrise" : "05:55",
"Sunset" : "17:27",
"app_version" : "4.9700",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Color" : "{\"b\":242,\"cw\":0,\"g\":255,\"m\":3,\"r\":224,\"t\":0,\"ww\":0}",
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"DimmerType" : "abs",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "Diody kolorowe",
"HardwareType" : "H801 LED WiFi Controller with Tasmota firmware",
"HardwareTypeVal" : 94,
"HaveDimmer" : true,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "00040001",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2019-03-10 18:43:15",
"Level" : 100,
"LevelInt" : 100,
"MaxDimLevel" : 100,
"Name" : "Diody kolorowe - RGB",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RGB",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Color Switch",
"TypeImg" : "dimmer",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "6"
"status" : "OK",
"title" : "Devices"
Lokonli
Re: H801 RGB
Your device has subtype RGB. Diving into the Dashticz code it seems Dashticz currently only recognizes RGBW and RGBWW devices.credens wrote: Monday 11 March 2019 5:50Code: Select all
{ "ActTime" : 1552279683, "AstrTwilightEnd" : "19:22", "AstrTwilightStart" : "03:60", "CivTwilightEnd" : "18:01", "CivTwilightStart" : "05:21", "DayLength" : "11:32", "NautTwilightEnd" : "18:41", "NautTwilightStart" : "04:41", "ServerTime" : "2019-03-11 05:48:03", "SunAtSouth" : "11:05", "Sunrise" : "05:55", "Sunset" : "17:27", "app_version" : "4.9700", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Color" : "{\"b\":242,\"cw\":0,\"g\":255,\"m\":3,\"r\":224,\"t\":0,\"ww\":0}", "CustomImage" : 0, "Data" : "Off", "Description" : "", "DimmerType" : "abs", "Favorite" : 1, "HardwareID" : 4, "HardwareName" : "Diody kolorowe", "HardwareType" : "H801 LED WiFi Controller with Tasmota firmware", "HardwareTypeVal" : 94, "HaveDimmer" : true, "HaveGroupCmd" : false, "HaveTimeout" : false, "ID" : "00040001", "Image" : "Light", "IsSubDevice" : false, "LastUpdate" : "2019-03-10 18:43:15", "Level" : 100, "LevelInt" : 100, "MaxDimLevel" : 100, "Name" : "Diody kolorowe - RGB", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "Off", "StrParam1" : "", "StrParam2" : "", "SubType" : "RGB", "SwitchType" : "Dimmer", "SwitchTypeVal" : 7, "Timers" : "false", "Type" : "Color Switch", "TypeImg" : "dimmer", "Unit" : 1, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "6" } ], "status" : "OK", "title" : "Devices" }
I'll contact you via PM probably tonight for some additional testing.
credens
Re: H801 RGB
When I change the device sub-type to rgbw, the color selector does not appear either.
Then in
"SubType" : "RGBWZ"
Also as I create a virtual RGB or RGBW switch unrelated to H801, there is also no color selector in dashticz.
Then in
http://<domoticz ip>:<port>/json.htm?type=devices&rid=123Also as I create a virtual RGB or RGBW switch unrelated to H801, there is also no color selector in dashticz.
Lokonli
Re: H801 RGB
Fix will be merged in the next beta.Lokonli wrote: Monday 11 March 2019 12:27Your device has subtype RGB. Diving into the Dashticz code it seems Dashticz currently only recognizes RGBW and RGBWW devices.credens wrote: Monday 11 March 2019 5:50Code: Select all
robgeerts
- Domoticz version: 3.7067
Re: H801 RGB
Available in beta nowLokonli wrote: Monday 11 March 2019 21:22Fix will be merged in the next beta.Lokonli wrote: Monday 11 March 2019 12:27Your device has subtype RGB. Diving into the Dashticz code it seems Dashticz currently only recognizes RGBW and RGBWW devices.credens wrote: Monday 11 March 2019 5:50Code: Select all
