Import weather data other than Wunderground
silver323
Re: Import weather data other than Wunderground
i have a question.
I have the counter on 5 days for the OWM so it shows 5 days.
But it's not showing on the whole lenght of the width. How I get this done? Have this in the column code
columns[2] = {}
columns[2]['blocks'] = [
'currentweather_big_owm',
'weather_owm',
columns[2]['width'] = 5;
columns[2] = {}
'weather_owm',
- EdwinK
- Domoticz version: BETA
At the moment, it looks like this for me, any way to fix it (easily)
Lokonli
It should work ...
Did you try refreshing the cache?
Maybe there accidentally is another row in your CONFIG.js with config['owm_days'] = 0 ?
jake
@LokonliLokonli wrote: Tuesday 05 March 2019 16:20 ...
It should work ...
Can you please have a look at the varying column height per day/time slot? As shown above in my screenshot a few posts back, it can have big impact on screen layout. It would be nice when the columns would always be of equal height and the same height. Therefore my suggestion to reserve a 2nd line for the weather forecast text.
Lokonli
I'll have a look.jake wrote: Tuesday 05 March 2019 16:58
@Lokonli
As a partial fix, add the following to custom.css for a fixed height of the complete block:
.weatherfull > .transbg {
height: 250px !important;
Lokonli
or prevent the line wrapping with:Lokonli wrote: Tuesday 05 March 2019 17:46I'll have a look.jake wrote: Tuesday 05 March 2019 16:58
@Lokonli
As a partial fix, add the following to custom.css for a fixed height of the complete block:Code: Select all
.weatherfull > .transbg { height: 250px !important; }
height: 170px !important;
white-space: nowrap !important;
Lokonli
Add the following to your custom/custom.js:silver323 wrote: Wednesday 27 February 2019 9:16 i have a question.
columns[2] = {}
'weather_owm',
width: 20%;
jake
@Lokonli, thanks, I tuned it to 195px to achieve a proper height and included the nowrapping as well. Now I have to wait for such a weather forecast where the linewrapping would occur normally (let's hope this takes a long time, since I have no issues with the text 'sunny'Lokonli wrote:or prevent the line wrapping with:Lokonli wrote: Tuesday 05 March 2019 17:46I'll have a look.jake wrote: Tuesday 05 March 2019 16:58
@Lokonli
.weatherfull > .transbg { height: 250px !important; }Code: Select all
.weatherfull > .transbg { height: 170px !important; white-space: nowrap !important; }
silver323
Thanks.. that was the trickLokonli wrote: Tuesday 05 March 2019 18:25Add the following to your custom/custom.js:silver323 wrote: Wednesday 27 February 2019 9:16 i have a question.
columns[2] = {}
'weather_owm',
columns[2]['width'] = 5;Code: Select all
.weatherfull > .transbg { width: 20%; }
TankySpanky
I have copied some settings from this thread but still i only get the 3 hour info,
I would like to have the 5 days view.
Is there a special setting i need to do ?
config['owm_country'] = 'BE';
config['owm_lang'] = 'nl_NL';
config['owm_days'] = '1';
config['owm_cnt'] = '6';
Last edited by TankySpanky on Tuesday 26 March 2019 21:17, edited 1 time in total.
Raspberry Pi 3 B+ & Domoticz Beta & Dashticz Beta = Headache :)
But it keeps you van the straat
Lokonli
Try withTankySpanky wrote: Tuesday 26 March 2019 21:02 Hello,
config['owm_country'] = 'BE'; config['owm_lang'] = 'nl_NL'; config['owm_days'] = '6'; config['owm_cnt'] = '6';
config['owm_days'] = 1;
config['owm_cnt'] = '5';
TankySpanky
Ty Lokonli,
But still same result
I tried also to change it in the settings.js
both settings are the same now but only 3 hours info
TankySpanky
Tis oplost
I found the problem, somewhere was stil a "days =0" far hidden in the long list of items
Pffft gives me a headache
hahahaha
Back to the other parts the agenda......
ty for the help matey
mojojojo490
- Domoticz version: 2020.2
Hi all, i have for now the OWM in Dashticz included.
The language is set to nl.
But, the language on the day's won't change to nl.....
Does anyone have a clue how to fix it?
My code is:
My code is:
config['owm_api'] = 'my-own-api-key';
config['owm_city'] = 'Heiloo';
config['owm_name'] = '';
config['owm_country'] = 'nl';
config['owm_lang'] = 'nl';
config['owm_min'] = 1;
config['static_weathericons'] = 0;
Starter RPi3B, Domoticz Stable 2020.2, 10x Qubino Mini Dimmer, 1x Qubino shutter
Plugwise Anna + Adam + 2x Koen-4 & 1x Floor; SolarEdge SE3000H
Dashticz v3
Dashticz v3
- HansieNL
Have you set config['language'] = 'nl_NL'; ?
If so you can try to change to en_US, refresh your browser and change it back to nl_NL and refresh your browser.
Or try to load Dashticz in incognito mode.
Most of the time is this kind of “problem” a cache issue.
Blah blah blah
Sarcas
- Domoticz version: 2022.1ß
Absoluut beginner here. Trying my first dashboard with my OpenWeatherMap settings. I get the layout of the blocks, but they are empty. When I test in Chrome the server response I get this link:
When I only paste the part after my local address, I get all the api data just fine. I have no idea what I am doing wrong, my settings look like all the examples here.
Any ideas?
thanks
http://192.168.8.156:8082/0https://api.openweathermap.org/data/2.5/weather?id=<mycitycode>&appid=<myapi>&lang=0&units=metricAny ideas?
thanks
Domoticz on rPi4 - RFXCOM RFXtrx433 USB - ZW090 Z-Stick Gen5 EU - IKEA Tradfri - Philips HUE - YouLess meter - SolarEdge
Backlash
- Domoticz version: Latest
Got the same issue, in domoticz is works fine but only in dashticz the blocks are empty.
Maybe a problem in Dasticz V3.5-master?
Backlash
nobody who can point us at the right direction?
- HansieNL
Just tried my config with Dashticz 3.5 master and the 'weather_owm' block has no problem.
What settings do you use (without API key)?
Blah blah blah
