Notification after switch is on for x minutes
gschmidt
Post by gschmidt »
Is there an example of a script which sends a notification when a switch is on and when it is on for X minutes?
can't figure it out with blockly
Greetzzz,
Gerben
genepi
Re: Notification after switch is on for x minutes
Post by genepi »
gschmidt wrote: Saturday 02 March 2019 17:34 Hi,
Greetzzz,
Gerben
Could be something like
-- Check Switches.lua
local deviceNamesArray = {"Test_1", "Test_2",}
            on =
                        devices = deviceNamesArray,
                        timer = {'every 5 minutes'},
        logging    =
                            level       =  domoticz.LOG_DEBUG,
                            marker      =  "Check switches"
    execute = function(dz,item)
        local function logWrite(str,level)             -- Support function for shorthand debug log statements
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local maxOnTime = 15  -- maxOnTime in minutes
        local myNotificationTable   = {
                                                        -- table with one or more notification system.
                                                        -- Can be one or more of
                                                        -- dz.NSS_GOOGLE_CLOUD_MESSAGING,
                                                        dz.NSS_PUSHOVER,
                                                        -- dz.NSS_HTTP,
                                                        -- dz.NSS_KODI,
                                                        -- dz.NSS_LOGITECH_MEDIASERVER,
                                                        -- dz.NSS_NMA,
                                                        -- dz.NSS_PROWL,
                                                        -- dz.NSS_PUSHALOT,
                                                        -- dz.NSS_PUSHBULLET,
                                                        -- dz.NSS_PUSHOVER,
                                                        -- dz.NSS_PUSHSAFER,
                                } -- uncomment the ones you need
        if item.isTimer  then
            for index, deviceName in ipairs(deviceNamesArray) do
                local device = dz.devices(deviceNamesArray[index])
                if device.active and device.lastUpdate.minutesAgo > maxOnTime then
                    local message = "device " .. device.name .. " already on for " .. tostring(device.lastUpdate.minutesAgo) .. " minutes."
                    logWrite ("Check switch: " .. message)
                    dz.notify("Check switch",message,nil,nil,"",  myNotificationTable )
        elseif item.active then
            logWrite(item.name .. " is switched on.")
            dz.notify("Check switch","device " .. item.name .. " switched on" ,nil,nil,"",  myNotificationTable )
gschmidt
Post by gschmidt »
waaren wrote: Saturday 02 March 2019 18:46
Greetzzz,
Gerben
            on =
        logging    =
                                                        dz.NSS_PUSHOVER,
                                                        -- dz.NSS_HTTP,
                                                        -- dz.NSS_KODI,
                                                        -- dz.NSS_NMA,
                                                        -- dz.NSS_PROWL,
                                                        -- dz.NSS_PUSHALOT,
                                                        -- dz.NSS_PUSHOVER,
I get an error in the log when using this script:
Error: EventSystem: in Frietpan_timer: [string "-- Check Switches.lua..."]:12: attempt to index global 'domoticz' (a nil value)
gschmidt
Post by gschmidt »
I already got it....it is a dzVents Script and not a LUA
Users browsing this forum: jjnh and 1 guest
