Is there an example of a script which sends a notification when a switch is on and when it is on for X minutes?
can't figure it out with blockly
Greetzzz,
Gerben
Notification after switch is on for x minutes
- waaren
Re: Notification after switch is on for x minutes
Could be something likegschmidt wrote: Saturday 02 March 2019 17:34 Hi,
Greetzzz,
Gerben
-- Check Switches.lua
local deviceNamesArray = {"Test_1", "Test_2",}
on =
devices = deviceNamesArray,
timer = {'every 5 minutes'},
logging =
level = domoticz.LOG_DEBUG,
marker = "Check switches"
execute = function(dz,item)
local function logWrite(str,level) -- Support function for shorthand debug log statements
dz.log(tostring(str),level or dz.LOG_DEBUG)
local maxOnTime = 15 -- maxOnTime in minutes
local myNotificationTable = {
-- table with one or more notification system.
-- Can be one or more of
-- dz.NSS_GOOGLE_CLOUD_MESSAGING,
dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_LOGITECH_MEDIASERVER,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHBULLET,
-- dz.NSS_PUSHOVER,
-- dz.NSS_PUSHSAFER,
} -- uncomment the ones you need
if item.isTimer then
for index, deviceName in ipairs(deviceNamesArray) do
local device = dz.devices(deviceNamesArray[index])
if device.active and device.lastUpdate.minutesAgo > maxOnTime then
local message = "device " .. device.name .. " already on for " .. tostring(device.lastUpdate.minutesAgo) .. " minutes."
logWrite ("Check switch: " .. message)
dz.notify("Check switch",message,nil,nil,"", myNotificationTable )
elseif item.active then
logWrite(item.name .. " is switched on.")
dz.notify("Check switch","device " .. item.name .. " switched on" ,nil,nil,"", myNotificationTable )
}Debian buster, bullseye on RPI-4, Intel NUC.
gschmidt
I get an error in the log when using this script:waaren wrote: Saturday 02 March 2019 18:46Could be something likegschmidt wrote: Saturday 02 March 2019 17:34 Hi,
Greetzzz,
Gerben
-- Check Switches.lua local deviceNamesArray = {"Test_1", "Test_2",} return { on = { devices = deviceNamesArray, timer = {'every 5 minutes'}, }, logging = { level = domoticz.LOG_DEBUG, marker = "Check switches" }, execute = function(dz,item) local function logWrite(str,level) -- Support function for shorthand debug log statements dz.log(tostring(str),level or dz.LOG_DEBUG) end local maxOnTime = 15 -- maxOnTime in minutes local myNotificationTable = { -- table with one or more notification system. -- Can be one or more of -- dz.NSS_GOOGLE_CLOUD_MESSAGING, dz.NSS_PUSHOVER, -- dz.NSS_HTTP, -- dz.NSS_KODI, -- dz.NSS_LOGITECH_MEDIASERVER, -- dz.NSS_NMA, -- dz.NSS_PROWL, -- dz.NSS_PUSHALOT, -- dz.NSS_PUSHBULLET, -- dz.NSS_PUSHOVER, -- dz.NSS_PUSHSAFER, } -- uncomment the ones you need if item.isTimer then for index, deviceName in ipairs(deviceNamesArray) do local device = dz.devices(deviceNamesArray[index]) if device.active and device.lastUpdate.minutesAgo > maxOnTime then local message = "device " .. device.name .. " already on for " .. tostring(device.lastUpdate.minutesAgo) .. " minutes." logWrite ("Check switch: " .. message) dz.notify("Check switch",message,nil,nil,"", myNotificationTable ) end end elseif item.active then logWrite(item.name .. " is switched on.") dz.notify("Check switch","device " .. item.name .. " switched on" ,nil,nil,"", myNotificationTable ) end end }
Error: EventSystem: in Frietpan_timer: [string "-- Check Switches.lua..."]:12: attempt to index global 'domoticz' (a nil value)-
gschmidt
I already got it....it is a dzVents Script and not a LUA
