domoticz in synology as package! Available now.
Hi jumbotroll
A 6.2 version exist because I succeed installing domoticz_88f6281-6.2_3.0.9483-7 on my old 211J and it works very well.
I need a version with Python to install Zigate plugins, it doesn't exist for 88f6281 ?
Best regards
Jean luc
Best regards
Jean luc
Hi jumbotroll,
i known that your are very busy, and I am very sorry to trouble you but i am not able to find a solution by myself.
as i tell you a need a Domoticz version with Python plugins for my old DS 211 j Synology to install Zigate plugins.
I succeeded in installing domoticz_88f6281-5.2_3.0.8849-7. with Python plugins, but it doesn't want to launch.
what can i do, is there a suitable version for 88f6281 Ds 211 j ?
Best regards
Best regards
- supergroover
Hi Jumbotroll,
When you have some spare time, could you build a new package voor de Armadaxp dsm 6.2 beta with python?
There is a problem with blockly and dzVents link to topic.
This problem is solved in V4.10445.
- jumbotroll
Done and uploadedsupergroover wrote: ↑Thursday 21 February 2019 10:29 Hi Jumbotroll,
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- supergroover
Thank you very much!jumbotroll wrote: ↑Thursday 21 February 2019 11:49Done and uploadedsupergroover wrote: ↑Thursday 21 February 2019 10:29 Hi Jumbotroll,
Thanks!![]()
Hi @jumbotroll,
I'm getting the following in my log:
Here's what I just did:
1. Used this page to find out which architecture my Synology uses. Turns out it is Broadwellnk as uname -a shows Linux Hyperion 4.4.59+ #23824 SMP PREEMPT Tue Dec 25 18:27:57 CST 2018 x86_64 GNU/Linux synology_broadwellnk_3018xs.
2. Downloaded the Broadwellnk driver file.
3. Installed this file as a manual package in the Synology package center, it's showing as running status.
4. Pulled the USB stick in + out and got nothin. No ttyUSB*, ttyAMA0, or ttyACM0.
5. As you mentioned in a previous post, I've tried renaming usbserial.ko in /lib/modules to usbserial.ko.old and reboot to no avail.
6. I did notice a copy of the UsbSerialDrivers folder was placed in /usr/local/ in addition to the standard /volume1/@appstore/UsbSerialDrivers. The installation did not copy the driver files to /usr/lib/modules.
Keep in mind, I'm trying to get GoControl HUSBZB-1 Combo Stick to work.
Any thoughts on what else to try?
[ 193.400079] usbcore: registered new interface driver usbserial
[ 193.426258] usbcore: registered new interface driver ftdi_sio
[ 193.434111] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 193.511698] usbserial: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ 193.574980] ftdi_sio: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ 193.636414] cp210x: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ 193.660063] pl2303: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ 193.728309] ch341: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ 193.791661] ti_usb_3410_5052: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 480M
|__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 4, If 0, Class=Vendor Specific Class, Driver=, 12M
|__ Port 3: Dev 4, If 1, Class=Vendor Specific Class, Driver=, 12M
|__ Port 4: Dev 5, If 0, Class=Mass Storage, Driver=usb-storage, 480M
- jumbotroll
poldim wrote: ↑Sunday 24 February 2019 20:07 Hi @jumbotroll,
I will update the drivers in broadwellnk packages tonight with 4.4.59+ SMP drivers, this is a known problem...
I think your device GoControl HUSBZB-1 Combo Stick use the CP210x drivers, but I have not tested this device on synology.
The UsbSerialDrivers package for arch-broadwellnk is updated and the domoticz beta packages is updated
BTW the UsbSerialDrivers don't move to /lib/modules folder, they are insmod in the usr/local/... folder
Jumbotroll
Jumbotroll
Thanks for your help. I believ the stick does use the CP210x driver from what I've found online.jumbotroll wrote: ↑Sunday 24 February 2019 20:37 I will update the drivers in broadwellnk packages tonight with 4.4.59+ SMP drivers, this is a known problem...
I installed the new drivers and rebooted. Then tried unplugging and replugging the USB stick. Here's the log. Do I need to try renaming usbserial.ko in /lib/modules to usbserial.ko.old and reboot? I did notice a difference in output of lsusb before and after installing your SPK.
dmesg | grep usb
[ 191.770374] usbserial: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ 191.896894] ftdi_sio: Unknown symbol usb_serial_handle_sysrq_char (err 0)
[ 191.905984] ftdi_sio: Unknown symbol usb_serial_generic_open (err 0)
[ 191.915217] ftdi_sio: Unknown symbol usb_serial_handle_dcd_change (err 0)
[ 191.929166] ftdi_sio: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 191.947584] ftdi_sio: Unknown symbol usb_serial_generic_unthrottle (err 0)
[ 191.957625] ftdi_sio: Unknown symbol usb_serial_handle_break (err 0)
[ 191.972912] ftdi_sio: Unknown symbol usb_serial_generic_get_icount (err 0)
[ 191.981022] ftdi_sio: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 191.989776] ftdi_sio: Unknown symbol usb_serial_generic_throttle (err 0)
[ 192.000370] ftdi_sio: Unknown symbol usb_serial_register_drivers (err 0)
[ 192.047605] cp210x: Unknown symbol usb_serial_generic_open (err 0)
[ 192.055745] cp210x: Unknown symbol usb_serial_generic_close (err 0)
[ 192.063595] cp210x: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 192.075107] cp210x: Unknown symbol usb_serial_register_drivers (err 0)
[ 192.225075] pl2303: Unknown symbol usb_serial_handle_sysrq_char (err 0)
[ 192.232528] pl2303: Unknown symbol usb_serial_generic_open (err 0)
[ 192.239462] pl2303: Unknown symbol usb_serial_generic_close (err 0)
[ 192.246498] pl2303: Unknown symbol usb_serial_handle_dcd_change (err 0)
[ 192.253988] pl2303: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 192.261525] pl2303: Unknown symbol usb_serial_handle_break (err 0)
[ 192.268467] pl2303: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 192.276003] pl2303: Unknown symbol usb_serial_register_drivers (err 0)
[ 192.435947] ch341: Unknown symbol usb_serial_generic_open (err 0)
[ 192.442812] ch341: Unknown symbol usb_serial_generic_close (err 0)
[ 192.449768] ch341: Unknown symbol usb_serial_handle_dcd_change (err 0)
[ 192.460634] ch341: Unknown symbol usb_serial_generic_resume (err 0)
[ 192.474320] ch341: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 192.483634] ch341: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 192.497387] ch341: Unknown symbol usb_serial_register_drivers (err 0)
[ 192.570676] ti_usb_3410_5052: Unknown symbol usb_serial_deregister_drivers (err 0)
[ 192.580500] ti_usb_3410_5052: Unknown symbol usb_serial_generic_get_icount (err 0)
[ 192.589341] ti_usb_3410_5052: Unknown symbol usb_serial_generic_tiocmiwait (err 0)
[ 192.605445] ti_usb_3410_5052: Unknown symbol usb_serial_register_drivers (err 0)
- jumbotroll
Yes it's look like you have an old usbserial.ko driver in your system and maybe it's the /lib/module/usbserial.ko the t make some problem.poldim wrote: ↑Monday 25 February 2019 20:41
In my package the usbserial.ko is updated and insmod.
You can always try to rename the file and reboot...
Jumbotroll
Jumbotroll
I got it working!! Thank you!
Here's what I did:about halfway through the file I found this line:
Then I compared it with the other file:
Noticing that /usr/lib/modules/usbserial.ko had the + after 4.4.59, I decided to try to place it into your folder:
So now that I have it working, do I basically have to not perform DSM upgrades for fear of them breaking this driver compatibility? Or how can I learn to make these drivers for the correct DSM version on my own?
Here's what I did:
cat /usr/lib/modules/usbserial.ko
license=GPLdescription=USB Serial Driver coreauthor=Greg Kroah-Hartman <[email protected]>depends=usbcoreintree=Yvermagic=4.4.59+ SMP
cat /usr/local/UsbSerialDrivers/modules/usbserial.ko
license=GPLdescription=USB Serial Driver coreauthor=Greg Kroah-Hartman <[email protected]>depends=usbcoreintree=Yvermagic=4.4.59 SMP
sudo mv /usr/local/UsbSerialDrivers/modules/usbserial.ko /usr/local/UsbSerialDrivers/modules/usbserial.ko.original
sudo cp /usr/lib/modules/usbserial.ko /usr/local/UsbSerialDrivers/modules/usbserial.ko
sudo reboot now
dmesg | grep tty
[ 188.836041] usb 1-3: cp210x converter now attached to ttyUSB0
[ 188.848238] usb 1-3: cp210x converter now attached to ttyUSB1
I have a problem with the last beta Domoticz v4.0.10548-8. Now the notification is not working at all.
My synology is armada370 213J type.
In the log shiw only this: 2019-03-18 12:03:26.995 Error: Telegram:
2019-03-18 12:04:08.577 Error: Pushbullet:
2019-03-18 12:04:34.728 Error: Pushbullet:
2019-03-18 12:09:17.496 Error: Pushbullet:
2019-03-18 12:09:26.331 Error: Telegram:
2019-03-18 12:09:31.341 Error: Telegram:
2019-03-18 12:09:33.158 Error: Telegram:
2019-03-18 12:15:54.242 Error: Telegram:
2019-03-18 12:15:56.785 Error: Telegram:
still not working
and cant go back older beta because the synology package manager manual install not accept older beta domoticz.
2019-03-20 14:29:22.528 Notification sent (telegram) => Failed
2019-03-20 14:29:22.570 Active notification Subsystems: pushbullet, telegram (2/13)
2019-03-20 14:29:22.475 Status: Notification: Domoticz test
2019-03-20 14:29:22.527 Error: Telegram:
- Domoticz version: 4.10603
Today I updated to version 4.0.10570-8 and it seems to run but i don;t have a GUI to connect to.
Is this a know issue?
- jumbotroll
Working fine here.schumi2004 wrote: ↑Wednesday 27 March 2019 16:35 Today I updated to version 4.0.10570-8 and it seems to run but i don;t have a GUI to connect to.
Try to clear your browser, if that don't work, manually download 4.0.10570-8 and reinstall and check that http port is 8084 in wizard.
Jumbotroll
Jumbotroll
A manual reinstall did the trick, thanks for your helpjumbotroll wrote: ↑Wednesday 27 March 2019 16:52Working fine here.schumi2004 wrote: ↑Wednesday 27 March 2019 16:35 Today I updated to version 4.0.10570-8 and it seems to run but i don;t have a GUI to connect to.
I installed the pre-compiled Domoticz package on my DS215j but Domoticz is not started at reboot of my NAS.
How do I configure automatic startup I can not find the script domoticz.sh anywhere.
Thanks for you help
Thanks for you help
- jumbotroll
Domoticz start automatic on Synology. no need for edit startup.sh.
You have maybe installed the python plugin version and if you don't have Python 3 package from synology installed, the domoticz will not start.
Jumbotroll
Jumbotroll
@jumbotroll
Since i upgraded to version 4.10602 i see a issue with python plugin iDetect
(https://www.domoticz.com/forum/viewtopic.php?t=20467)
2019-04-19 13:26:56.629 Error: (iDetect Wifi presence detection) Aborting plugin initialization because SSH client could not be found
2019-04-19 13:27:06.779 Error: (iDetect Wifi presence detection) Plugin initialization did not complete successfully. Check the (debug) log for startup errors.
For some reason it can't find SSH client but it always worked and nothing has changed to the Synology system, no DSM upgrade or anything like that.
SSH still workes like before so no noticeable changes there either.
I can't downgrade easily because Synology doesn't let you.
Any ideas?
Any ideas?
- jumbotroll
Nothing changed in the package only updated domoticz from latest source.schumi2004 wrote: ↑Friday 19 April 2019 13:34 @jumbotroll
Any ideas?
Maybe something went wrong when you updated?
I have build the latest domoticz 4.10603 Alpine you can test or if that not work, maybe try to reinstall the plugin.
Jumbotroll
Jumbotroll
- waaren
Can you please also build this version with Python for Braswell- DSM 6.2. I want to test dzVents' domoticz.triggerIFTTT on my Synology 916+jumbotroll wrote: ↑Friday 19 April 2019 16:07 I have build the latest domoticz 4.10603 Alpine you can test or if that not work, maybe try to reinstall the plugin.
Many thanks !
