Smart meter in logfile
Franzie
- Domoticz version: 2020.1
I just installed a smart meter cable. Now, when I look into my logfile I see every second a notification from this meter. Is this normal? That often?
Frans
Frans
Re: Smart meter in logfile
Yes, every 10 seconds there is an update
- FireWizard
Hi Franzie,
That may be correct. It depends on the protocol of the smart meter. Older Smart Meters, with protocol DSMR 4.2 or earlier, emit a telegram every 10 seconds. The newer smart meters, with protocol DSMR 5.0 or newer, emit a telegram every second.
That fills the log file quite fast. However you can limit the number of updates by setting the "Rate Limit" in the hardware for the smart meter to the number of desired seconds.
Franzie
What can be a reasonable amount of updates?
- waaren
1 update per 10 seconds.
- FireWizard
Personally I use 1 update per 10 seconds as well. That is fine for me.
Franzie
More than enough
More than enough
reneklomp
Same 'problem'... instead of increasing the rate limit can't we configure the amount of logging (e.g. turn it off) it does somewhere?
When it is working It is just generating too much log information if you ask me.
Every second (or even 10 seconds) I get this which is not really meaningful:
2019-08-08 06:21:27.250 (Smart Meter) General/Voltage (Voltage L1)
2019-08-08 06:21:27.257 (Smart Meter) General/Voltage (Voltage L2)
2019-08-08 06:21:27.266 (Smart Meter) General/Voltage (Voltage L3)
2019-08-08 06:21:27.274 (Smart Meter) Usage (Usage L1)
2019-08-08 06:21:27.282 (Smart Meter) Usage (Usage L2)
2019-08-08 06:21:27.290 (Smart Meter) Usage (Usage L3)
2019-08-08 06:21:27.292 (Smart Meter) Usage (Delivery L1)
2019-08-08 06:21:27.294 (Smart Meter) Usage (Delivery L2)
2019-08-08 06:21:27.297 (Smart Meter) Usage (Delivery L3)
2019-08-08 06:21:27.307 (Smart Meter) P1 Smart Meter (Gas)
2019-08-08 06:21:37.249 (Smart Meter) P1 Smart Meter (Power)
Rene.
Rene.
Steef
I am curious about this too!
A fresh smart meter was installed here friday, and last night I saw that my used hdd space went from 17% to 48% within a week! On a 32gb card...
I have set the interval to 30 seconds now, also because my Raspberry was quite Hot because of all the updates..
But if someone knows a way how to free some hdd space, it is more than welcome!
MrRikkie
- Domoticz version: 2022.2
Hi does anybody have an update on this ? Is it possible to disable this meaningless logging ?
- waaren
'Meaningless" is kind of a subjective remark here but yes it is possible to disable the logging for this and all other logging in this class.MrRikkie wrote: Tuesday 21 July 2020 18:10 Hi does anybody have an update on this ? Is it possible to disable this meaningless logging ?
edit the file /etc/init.d/domoticz.sh and change the line with
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error"
DAEMON_ARGS="$DAEMON_ARGS -loglevel error"
then
sudo systemctl daemon-reload
sudo service domoticz stop
sudo service domoticz startDebian buster, bullseye on RPI-4, Intel NUC.
Users browsing this forum: imautohuttraeger and 1 guest
