Smart meter in logfile
Franzie
Domoticz version: 2020.1
Post by Franzie »
I just installed a smart meter cable. Now, when I look into my logfile I see every second a notification from this meter. Is this normal? That often?
Frans
renerene
Re: Smart meter in logfile
Post by renerene »
Yes, every 10 seconds there is an update
FireWizard
Post by FireWizard »
Hi Franzie,
That may be correct. It depends on the protocol of the smart meter. Older Smart Meters, with protocol DSMR 4.2 or earlier, emit a telegram every 10 seconds. The newer smart meters, with protocol DSMR 5.0 or newer, emit a telegram every second.
That fills the log file quite fast. However you can limit the number of updates by setting the "Rate Limit" in the hardware for the smart meter to the number of desired seconds.
Franzie
Post by Franzie »
What can be a reasonable amount of updates?
Franzie wrote: Sunday 24 February 2019 16:55 What can be a reasonable amount of updates?
1 update per 10 seconds.
FireWizard
Personally I use 1 update per 10 seconds as well. That is fine for me.
Franzie
Post by Franzie »
More than enough :)
reneklomp
Post by reneklomp »
Same 'problem'... instead of increasing the rate limit can't we configure the amount of logging (e.g. turn it off) it does somewhere?
When it is working It is just generating too much log information if you ask me.
Every second (or even 10 seconds) I get this which is not really meaningful:
2019-08-08 06:21:27.250 (Smart Meter) General/Voltage (Voltage L1)
2019-08-08 06:21:27.257 (Smart Meter) General/Voltage (Voltage L2)
2019-08-08 06:21:27.266 (Smart Meter) General/Voltage (Voltage L3)
2019-08-08 06:21:27.274 (Smart Meter) Usage (Usage L1)
2019-08-08 06:21:27.282 (Smart Meter) Usage (Usage L2)
2019-08-08 06:21:27.290 (Smart Meter) Usage (Usage L3)
2019-08-08 06:21:27.292 (Smart Meter) Usage (Delivery L1)
2019-08-08 06:21:27.294 (Smart Meter) Usage (Delivery L2)
2019-08-08 06:21:27.297 (Smart Meter) Usage (Delivery L3)
2019-08-08 06:21:27.307 (Smart Meter) P1 Smart Meter (Gas)
2019-08-08 06:21:37.249 (Smart Meter) P1 Smart Meter (Power)
Rene.
Steef
Post by Steef »
I am curious about this too!
A fresh smart meter was installed here friday, and last night I saw that my used hdd space went from 17% to 48% within a week! On a 32gb card...
I have set the interval to 30 seconds now, also because my Raspberry was quite Hot because of all the updates..
But if someone knows a way how to free some hdd space, it is more than welcome!
MrRikkie
Domoticz version: 2022.2
Post by MrRikkie »
Hi does anybody have an update on this ? Is it possible to disable this meaningless logging ?
MrRikkie wrote: Tuesday 21 July 2020 18:10 Hi does anybody have an update on this ? Is it possible to disable this meaningless logging ?
'Meaningless" is kind of a subjective remark here but yes it is possible to disable the logging for this and all other logging in this class.
edit the file /etc/init.d/domoticz.sh and change the line with
DAEMON_ARGS="$DAEMON_ARGS -loglevel  normal,status,error"
to
DAEMON_ARGS="$DAEMON_ARGS -loglevel  error"
save the changed file and exit the editor
then
sudo systemctl daemon-reload
sudo service domoticz stop
sudo service domoticz start
and you won't get these loglines in the GUI and / or in the OS logfile
