Dashticz - Beta 2.5.5
Lokonli
Post by Lokonli »
* Blink on change.
If you set the flash parameter to a block definition, then the block will flash when the value changes.
The flash parameter determines the duration of the flash. You define it as follows for a 2x1 second duration:
blocks[107]['flash'] = 1000;
The background flash color can be set to a specific color as follows:
config['blink_color'] = '255, 255, 255, 1';
* Fix for OWM weather not always displayed correctly
* Buttons: load frame after button click
Via the url-parameter of a button you can define the url that should be loaded in the frame that appears after you click/press the button. In the past this frame content was continuously refreshed in the background, creating some issues. Now the frame content only get loaded once as soon as the frame becomes visible. There can be a slight delay. If this delay is too long for you, then please make a reply in this thread (or the bug-report thread)
* Moon image
The moon phase image doesn't depend on Domoticz anymore. You can use it by defining a button with the custom image 'moon' and add this button to a column definition (as in the past):
buttons.moon = {width:12, isimage:true, refreshimage:60000, image: 'moon'}
columns[2] = {}
columns[2]['blocks'] = [
  buttons.moon
* Block title configurable
Added on option to hide the block title, so the data value can take up more space.
blocks['567_1'] = {} //utetemperatur
blocks['567_1']['title'] = 'Utetemperatur'
blocks['567_1']['width'] = 2;
blocks['567_1']['hide_title'] = true;
blocks['567_1']['last_update'] = true;
* Fix for public transport provide 9292-tram and 9292-tram-bus
* Fix for background refresh of news
* Calendar improvements
Improved handling of recurring events. Hopefully all issues are solved now.
* Translations
Recreated the project at lokalize.co for managing the language file. If you would like to contribute to the translations send me a PM.
Added Lithuanian translations.
Improved Norwegian translations.
For updating to the most recent beta, see:
https://www.domoticz.com/wiki/Dashticz_ ... ta_release
HansieNL
Re: Dashticz - Beta 2.5.5
Post by HansieNL »
Just installed version 2.5.5 Beta and something strange happens. The screen is totally mixed up. If I click somewhere on this page all my buttons are loaded in separate tabs. Is it just me having this problem?
Blah blah blah
Lokonli
Post by Lokonli »
I've tested on Firefox (Linux), Chrome (Windows), Fully Kiosk (Android), Safari (iPad): no issues.
Maybe some interaction with your cache? or your custom.css?
rleunk
Post by rleunk »
I had a same kind of problem, adding the lines below from the custum.js to my own custom.js solved the problem in my case.
function getExtendedBlockTypes(blocktypes){
//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
return blocktypes;
HansieNL
Post by HansieNL »
@rleunk Thanks, that solved the problem :D
Blah blah blah
silver323
Post by silver323 »
With the last update my domoticz log stays empty. Log in domoticz
I have a button in the block.
buttons.domoticz = {key:'log', width:3, icon:'fas fa-microchip', title: 'Domoticz Log', log:true, level: 2}
More with this problem?
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Thanks for the updates...
Still dont see a update log for 2.5.7 ..
However.. How to set the FLASH to true for all blocks?
Lokonli
Post by Lokonli »
Minglarn wrote: Friday 08 March 2019 18:33 Thanks for the updates...
I'll write some release notes in the weekend.
On flash: the choice was default on, default off, or configurable.
I prefer to minimize impact for existing users. So that ruled out default on. If more people would like to see default on behavior for Flash then I'll add the setting for CONFIG.js.
Minglarn
Post by Minglarn »
I would appreciate if there's an option for it..
Set it for false as standard, let the users choose ... :D
Big thanks for the time you put in this!
Good work!
