Xiaomi IR Remote
DAVIZINHO
Xiaomi IR Remote
Post by DAVIZINHO »
I have domoticz configure and working fine with miio library (with air purifier configured OK)
I have a XIAOMI IR REMOTE, and i want to integrate it in domoticz. Anyone have idea???
thanks
DAVIZINHO
Re: Xiaomi IR Remote
Post by DAVIZINHO »
nobody have the xiaomi IR remote??
DAVIZINHO
Post by DAVIZINHO »
Hello again,
I still investigating and fin some info:
python library that suuports Xiaomi IR Remote:
https://github.com/rytilahti/python-miio#id27
I install the library in my raspberry, but im a noob with python and i dont know how to progress :-(
wmmudde
Post by wmmudde »
Have this working allready?
DAVIZINHO
Post by DAVIZINHO »
Yes, it works fine:
you must use this library:
and the create scripts:
IR.PY for learn the comand and save it to a codes.txt file
#!/usr/bin/python3
import sys
import ipaddress
from typing import Any
from miio import ChuangmiIr,DeviceException
import time
import json
num_lines = sum(1 for line in open('codes.txt'))
print ('Stored Ir Keys  ->'+ str(num_lines) )
id = num_lines + 1
ir =  ChuangmiIr('your.IP','your token')
ir.learn(key=1)
time.sleep(10)
print (ir.read(key=1).get("code"))
with open('codes.txt', 'a') as file:
 	file.write(ir.read(key=1).get("code")+ '\n')
and this other script to irsend.py to send the comand (irsend.py 15), this send the comand in line 15 of your codes.txt
#!/usr/bin/python3
import sys
import ipaddress
import time
f=open('/home/pi/Xiaomi/IR/SALON/codes.txt')
codeline=f.readlines()
#id = codeline[int(sys.argv[1])-1]
id_aux = codeline[int(sys.argv[1])-1].split(" ")
id=id_aux[0]
ir =  ChuangmiIr('YOUR.IP','YOUR.TOKEN')
ir.play(id,frequency='')
then integrate with virtual switches in domoticz and ready.
Sorry for the poor explanation but i dont have much time :-(
nickmorgan
Post by nickmorgan »
I will correct not much
In the script irsend.py the last line should look like this
ir.play_raw (id,frequency='')
only so I sent the code
You can also send commands with the following code
mirobo --ip 192.168.0.25 --token 689c4056fe28ebb3a2e8c2fe350e51ba raw_command miIO.ir_play '{"freq": 38400, "code": "base64..."}'
which is much easier to install into other scripts
Sorry for my bad english :)
DoMoney
Post by DoMoney »
nickmorgan wrote: Friday 16 March 2018 10:50 I will correct not much
Please advice, where can I get the token of Xiaomi IR controller?
salvacalatayud
Post by salvacalatayud »
Do you know how to comand the Xiaomi Mi Home Air Conditioner Companion? It is supported by miio
I only need to turn on and off, but I didn't find the way
Woxa
Post by Woxa »
Faced with a similar problem
dzintars
Post by dzintars »
The above version works with the previous version of XIAOMI remote control (with MI letters on the body). Does not work with the 2019 remote control (with MI logo) with air conditioning. It works with TV and audio systems but doesn't work with air conditioners (York, Mitsibishi, Tadirian.) It looks like the company XIAOMI is specifically forbidden to run air conditioners. Maybe somebody has a solution to run air conditioners with IR from DomoticZ?
