Xiaomi IR Remote
DAVIZINHO
Xiaomi IR Remote
I have domoticz configure and working fine with miio library (with air purifier configured OK)
I have a XIAOMI IR REMOTE, and i want to integrate it in domoticz. Anyone have idea???
thanks
thanks
DAVIZINHO
Re: Xiaomi IR Remote
nobody have the xiaomi IR remote??
DAVIZINHO
Hello again,
I still investigating and fin some info:
python library that suuports Xiaomi IR Remote:
https://github.com/rytilahti/python-miio#id27
I install the library in my raspberry, but im a noob with python and i dont know how to progress
wmmudde
Have this working allready?
DAVIZINHO
Yes, it works fine:
you must use this library:
and the create scripts:
IR.PY for learn the comand and save it to a codes.txt file
and this other script to irsend.py to send the comand (irsend.py 15), this send the comand in line 15 of your codes.txt
then integrate with virtual switches in domoticz and ready.
Sorry for the poor explanation but i dont have much time
#!/usr/bin/python3
import sys
import ipaddress
from typing import Any
from miio import ChuangmiIr,DeviceException
import time
import json
num_lines = sum(1 for line in open('codes.txt'))
print ('Stored Ir Keys ->'+ str(num_lines) )
id = num_lines + 1
ir = ChuangmiIr('your.IP','your token')
ir.learn(key=1)
time.sleep(10)
print (ir.read(key=1).get("code"))
with open('codes.txt', 'a') as file:
file.write(ir.read(key=1).get("code")+ '\n')
#!/usr/bin/python3
import sys
import ipaddress
import time
f=open('/home/pi/Xiaomi/IR/SALON/codes.txt')
codeline=f.readlines()
#id = codeline[int(sys.argv[1])-1]
id_aux = codeline[int(sys.argv[1])-1].split(" ")
id=id_aux[0]
ir = ChuangmiIr('YOUR.IP','YOUR.TOKEN')
ir.play(id,frequency='')
nickmorgan
I will correct not much
In the script irsend.py the last line should look like this
only so I sent the code
You can also send commands with the following code
which is much easier to install into other scripts
Sorry for my bad english
ir.play_raw (id,frequency='')You can also send commands with the following code
mirobo --ip 192.168.0.25 --token 689c4056fe28ebb3a2e8c2fe350e51ba raw_command miIO.ir_play '{"freq": 38400, "code": "base64..."}'Sorry for my bad english
DoMoney
Please advice, where can I get the token of Xiaomi IR controller?nickmorgan wrote: Friday 16 March 2018 10:50 I will correct not much
In the script irsend.py the last line should look like thisonly so I sent the codeCode: Select all
You can also send commands with the following codewhich is much easier to install into other scriptsCode: Select all
Sorry for my bad english![]()
salvacalatayud
Do you know how to comand the Xiaomi Mi Home Air Conditioner Companion? It is supported by miio
I only need to turn on and off, but I didn't find the way
Woxa
Faced with a similar problem
dzintars
The above version works with the previous version of XIAOMI remote control (with MI letters on the body). Does not work with the 2019 remote control (with MI logo) with air conditioning. It works with TV and audio systems but doesn't work with air conditioners (York, Mitsibishi, Tadirian.) It looks like the company XIAOMI is specifically forbidden to run air conditioners. Maybe somebody has a solution to run air conditioners with IR from DomoticZ?
