domoticz property  [Solved]
pvklink
Domoticz version: latest b
domoticz property
Post by pvklink »
Is it possible to get the domoticz setting: settings/location/name into a dzvents variable?
I like to use this description for my events. I manage more than one domoticz enviroments that uses the same scripts with notifications.
I cant see which notification comes from which domitcz server. So my solution is the use the settings/location/name
Jablotron connection, Ikea
emme
Re: domoticz property
Post by emme »
why don't set up a user variable with the system/environment name and add it to each notification message?
"We always done this way"
pvklink wrote: Wednesday 06 February 2019 10:27 Is it possible to get the domoticz setting: settings/location/name into a dzvents variable?
Is possible but not with a simple command. Much easier to add a var to global_data.lua so you can access it from every dzVents script.
pvklink
Post by pvklink »
ok, thanks all!
pvklink wrote: Wednesday 06 February 2019 10:27 Is it possible to get the domoticz setting: settings/location/name into a dzVents variable?
I like to use this description for my events. I manage more than one domoticz environment that uses the same scripts with notifications.
I cant see which notification comes from which domoticz server. So my solution is the use the settings/location/name
In V4.10420 (dzVents 2.4.13) I introduced the possibility to use this setting directly in dzVents. Use domoticz.settings.location
papoo
Domoticz version: 4.10
Re: domoticz property  [Solved]
Post by papoo »
waaren wrote: Thursday 07 February 2019 13:30
thanks
there is a way to add latitude and longitude? number of weather scripts use this information
papoo wrote: Thursday 07 February 2019 13:44
thanks
Yes, I have a PR in preparation for this. Probably in a beta later this week.
papoo
Post by papoo »
Cool
You are the boss
pvklink
Post by pvklink »
:D works like a charm
pvklink wrote: Friday 08 February 2019 19:02 :D works like a charm
Breaking change in latest Beta (dzVents >= 2.4.14)
location name is now under domoticz.settings.location.name
papoo wrote: Thursday 07 February 2019 13:44 there is a way to add latitude and longitude? number of weather scripts use this information
Available in dzVents >= 2.4.14 (domoticz >= V4.10444)
using domoticz.settings.location.latitude and domoticz.settings.location.longitude
papoo
Post by papoo »
Great
