domoticz property [Solved]
pvklink
- Domoticz version: latest b
domoticz property
Is it possible to get the domoticz setting: settings/location/name into a dzvents variable?
I like to use this description for my events. I manage more than one domoticz enviroments that uses the same scripts with notifications.
I cant see which notification comes from which domitcz server. So my solution is the use the settings/location/name
Jablotron connection, Ikea
- emme
Re: domoticz property
why don't set up a user variable with the system/environment name and add it to each notification message?
"We always done this way"
- waaren
Is possible but not with a simple command. Much easier to add a var to global_data.lua so you can access it from every dzVents script.pvklink wrote: Wednesday 06 February 2019 10:27 Is it possible to get the domoticz setting: settings/location/name into a dzvents variable?
pvklink
ok, thanks all!
- waaren
In V4.10420 (dzVents 2.4.13) I introduced the possibility to use this setting directly in dzVents. Use domoticz.settings.locationpvklink wrote: Wednesday 06 February 2019 10:27 Is it possible to get the domoticz setting: settings/location/name into a dzVents variable?
I like to use this description for my events. I manage more than one domoticz environment that uses the same scripts with notifications.
I cant see which notification comes from which domoticz server. So my solution is the use the settings/location/name
- papoo
- Domoticz version: 4.10
Re: domoticz property [Solved]
thankswaaren wrote: Thursday 07 February 2019 13:30
there is a way to add latitude and longitude? number of weather scripts use this information
- waaren
Yes, I have a PR in preparation for this. Probably in a beta later this week.papoo wrote: Thursday 07 February 2019 13:44thankswaaren wrote: Thursday 07 February 2019 13:30
pvklink
- waaren
Breaking change in latest Beta (dzVents >= 2.4.14)
location name is now under domoticz.settings.location.name
- waaren
Available in dzVents >= 2.4.14 (domoticz >= V4.10444)papoo wrote: Thursday 07 February 2019 13:44 there is a way to add latitude and longitude? number of weather scripts use this information
using domoticz.settings.location.latitude and domoticz.settings.location.longitude
