fronius plugin
tjabas
fronius plugin
Post by tjabas »
Hi!
i found this plugin: https://github.com/aukedejong/domoticz- ... ter-plugin
i have tried it but Domoticz freezes after installation.
anyone who has tried it?
tjabas
Re: fronius plugin
Post by tjabas »
anyone?
besix
Re: fronius plugin
Post by besix »
tjabas wrote: Tuesday 22 January 2019 17:12 Hi!
Hey
The plug-in works without a problem for a stable last domoticz.
You need only Python 3.4.2 or higher + Python pip, dev.
tjabas
Re: fronius plugin
Post by tjabas »
ok, i havent tried it with the latest stable domoticz though, i run the latest beta, domoticz crashes when i starts this plugin, i cant really understand why its like that.
any suggestions?
tjabas
Re: fronius plugin
Post by tjabas »
where can i find the device id for the fronius?
marcojpolet
Re: fronius plugin
Post by marcojpolet »
I installed this plugin (I used device ID 1, not sure if that is correct). I enabled Logging.
I now get this error message:
2019-02-13 20:29:05.998 Error: (Fronius) 'onHeartbeat' failed 'TypeError':''NoneType' object is not subscriptable'.
2019-02-13 20:29:05.998 Error: (Fronius) ----> Line 181 in '/home/pi/domoticz/plugins/domoticz-fronius-inverter-plugin/plugin.py', function onHeartbeat
2019-02-13 20:29:05.998 Error: (Fronius) ----> Line 63 in '/home/pi/domoticz/plugins/domoticz-fronius-inverter-plugin/plugin.py', function onHeartbeat
2019-02-13 20:29:05.998 Error: (Fronius) ----> Line 110 in '/home/pi/domoticz/plugins/domoticz-fronius-inverter-plugin/plugin.py', function isInverterActive
Any idea how I can fix that?
Regards,
Marco
tjabas
Re: fronius plugin
Post by tjabas »
i also tried that plugin but it didnt work, Domoticz froze everytime i started that plugin, instead i tried this metod: viewtopic.php?f=61&t=15037&hilit=fronius
it worked good, but alot more work.
Sofia431
Re: fronius plugin
Post by Sofia431 »
I have a similar setup - I've no direct experience in writing apps but I'd be interested to know if you are going ahead and happy to share any data or testing if it would help you.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
