fronius plugin
tjabas
fronius plugin
Post by tjabas »
Hi!
i found this plugin: https://github.com/aukedejong/domoticz- ... ter-plugin
i have tried it but Domoticz freezes after installation.
anyone who has tried it?
tjabas
Re: fronius plugin
Post by tjabas »
anyone?
besix
Re: fronius plugin
Post by besix »
tjabas wrote: Tuesday 22 January 2019 17:12 Hi!
Hey
The plug-in works without a problem for a stable last domoticz.
You need only Python 3.4.2 or higher + Python pip, dev.
tjabas
Re: fronius plugin
Post by tjabas »
ok, i havent tried it with the latest stable domoticz though, i run the latest beta, domoticz crashes when i starts this plugin, i cant really understand why its like that.
any suggestions?
tjabas
Re: fronius plugin
Post by tjabas »
where can i find the device id for the fronius?
marcojpolet
Re: fronius plugin
Post by marcojpolet »
I installed this plugin (I used device ID 1, not sure if that is correct). I enabled Logging.
I now get this error message:
2019-02-13 20:29:05.998 Error: (Fronius) 'onHeartbeat' failed 'TypeError':''NoneType' object is not subscriptable'.
2019-02-13 20:29:05.998 Error: (Fronius) ----> Line 181 in '/home/pi/domoticz/plugins/domoticz-fronius-inverter-plugin/plugin.py', function onHeartbeat
2019-02-13 20:29:05.998 Error: (Fronius) ----> Line 63 in '/home/pi/domoticz/plugins/domoticz-fronius-inverter-plugin/plugin.py', function onHeartbeat
2019-02-13 20:29:05.998 Error: (Fronius) ----> Line 110 in '/home/pi/domoticz/plugins/domoticz-fronius-inverter-plugin/plugin.py', function isInverterActive
Any idea how I can fix that?
Regards,
Marco
tjabas
Re: fronius plugin
Post by tjabas »
i also tried that plugin but it didnt work, Domoticz froze everytime i started that plugin, instead i tried this metod: viewtopic.php?f=61&t=15037&hilit=fronius
it worked good, but alot more work.
Sofia431
Re: fronius plugin
Post by Sofia431 »
I have a similar setup - I've no direct experience in writing apps but I'd be interested to know if you are going ahead and happy to share any data or testing if it would help you.
