My Domoticz server is going crazy sending me emails with Hive issues.
Out so not able to look.
My log is full of errors too. I'm also unable to log in to the Hive website - "Sorry, we can't find these login details. Please check and try again."sach wrote: Saturday 09 February 2019 16:57 Anything happening right now?
It would be interesting to know how many people are using version 1.0 without issue? I have had the same problems as mark.sellwood.mark.sellwood wrote: Wednesday 13 February 2019 7:52 Go to Setup then Devices, select Not Used, you should see them listed.
Please keep an eye on memory usage, on my Pi I have had to stop using this plugin as it uses all the memory in about 7 days then the Pi crashes.
2019-02-13 11:36:27.415 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2019-02-13 11:36:27.416 Status: Build Hash: a3a45906, Date: 2018-06-23 15:24:51
2019-02-13 11:36:27.416 Status: Startup Path: /home/osmc/domoticz/
2019-02-13 11:36:27.533 Status: EventSystem: reset all events...
2019-02-13 11:36:29.782 Status: (Hive) Started.
2019-02-13 11:36:29.783 Status: EventSystem: reset all events...
2019-02-13 11:36:29.784 Status: EventSystem: reset all device statuses...
2019-02-13 11:36:29.938 Status: Python EventSystem: Initalizing event module.
2019-02-13 11:36:29.939 Status: EventSystem: Queue thread started...
2019-02-13 11:36:29.939 Status: EventSystem: Started
2019-02-13 11:36:30.051 Status: PluginSystem: Entering work loop.
2019-02-13 11:36:30.212 Status: (Hive) Entering work loop.
2019-02-13 11:36:30.212 Status: (Hive) Initialized version 1.0, author 'imcfarla, MikeF and roadsnail'
2019-02-13 11:51:42.906 Status: (Hive) Started.
2019-02-13 11:51:43.055 Status: (Hive) Entering work loop.
2019-02-13 11:51:43.055 Status: (Hive) Initialized version 1.0, author 'imcfarla, MikeF and roadsnail'
2019-02-13 11:55:18.841 Status: (Hive) Stop directive received.
2019-02-13 11:55:19.041 Status: (Hive) Stopping threads.
2019-02-13 11:55:19.094 Status: (Hive) Exiting work loop.
2019-02-13 11:55:19.094 Status: (Hive) Stopped.
2019-02-13 11:55:34.683 Status: (Hive) Stop directive received.
2019-02-13 11:55:34.883 Status: (Hive) Stopping threads.
2019-02-13 11:55:35.056 Status: (Hive) Exiting work loop.
2019-02-13 11:55:35.056 Status: (Hive) Stopped.
2019-02-13 11:55:35.056 Status: (Hive) Started.
2019-02-13 11:55:35.210 Status: (Hive) Initialized version 1.0, author 'imcfarla, MikeF and roadsnail'
2019-02-13 11:55:35.209 Status: (Hive) Entering work loop.
2019-02-13 12:01:15.045 (Hive) onDisconnect called for Hive Devices
2019-02-13 12:01:15.221 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:01:15.246 PluginSystem: Restarting I/O service thread.
2019-02-13 12:01:15.246 (Hive) Disconnect event received for 'api.prod.bgchprod.info:443'.
2019-02-13 12:01:15.247 (Hive) onDisconnect called for Hive Session
2019-02-13 12:01:24.812 (Hive) onHeartbeat called
2019-02-13 12:01:24.813 (Hive) Counter = 5
2019-02-13 12:01:34.831 (Hive) onHeartbeat called
2019-02-13 12:01:34.831 (Hive) Counter = 6
2019-02-13 12:01:44.799 (Hive) onHeartbeat called
2019-02-13 12:01:44.802 (Hive) Getting Data
2019-02-13 12:01:44.802 (Hive) Getting Weather
2019-02-13 12:01:44.802 (Hive) Transport set to: 'TCP/IP', api.prod.bgchprod.info:443.
2019-02-13 12:01:44.845 PluginSystem: Starting I/O service thread.
2019-02-13 12:01:44.845 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:01:44.845 (Hive) Transport set to: 'TCP/IP', weather.prod.bgchprod.info:443.
2019-02-13 12:01:44.852 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:01:45.003 (Hive) onConnect called for Hive Weather
2019-02-13 12:01:45.003 (Hive) Getting Weather
2019-02-13 12:01:45.003 (Hive) Sending 152 bytes of data
2019-02-13 12:01:45.065 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:01:45.104 (Hive) onConnect called for Hive Devices
2019-02-13 12:01:45.104 (Hive) Getting Devices
2019-02-13 12:01:45.104 (Hive) Received 880 bytes of data
2019-02-13 12:01:45.105 (Hive) Disconnect event received for 'weather.prod.bgchprod.info:443'.
2019-02-13 12:01:45.107 (Hive) Sending 295 bytes of data
2019-02-13 12:01:45.107 (Hive) onMessage called for Hive Weather
2019-02-13 12:01:45.107 (Hive) onDisconnect called for Hive Weather
2019-02-13 12:01:45.158 (Hive) Received 530 bytes of data
2019-02-13 12:01:45.159 (Hive) onMessage called for Hive Devices
2019-02-13 12:01:45.159 (Hive) Transport set to: 'TCP/IP', api.prod.bgchprod.info:443.
2019-02-13 12:01:45.167 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:01:45.318 (Hive) onConnect called for Hive Session
2019-02-13 12:01:45.318 (Hive) Creating Session
2019-02-13 12:01:45.319 (Hive) b'{"sessions": [{"username": "blah", "password": "blah", "caller": "WEB"}]}'
2019-02-13 12:01:45.319 (Hive) Sending 304 bytes of data
2019-02-13 12:01:45.370 (Hive) Received 670 bytes of data
2019-02-13 12:01:45.371 (Hive) Received 5 bytes of data
2019-02-13 12:01:45.371 (Hive) onMessage called for Hive Session
2019-02-13 12:01:54.838 (Hive) onHeartbeat called
2019-02-13 12:01:54.839 (Hive) Counter = 2
2019-02-13 12:02:04.807 (Hive) onHeartbeat called
2019-02-13 12:02:04.807 (Hive) Counter = 3
2019-02-13 12:02:14.824 (Hive) onHeartbeat called
2019-02-13 12:02:14.824 (Hive) Counter = 4
2019-02-13 12:02:15.139 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:02:15.175 (Hive) Disconnect event received for 'api.prod.bgchprod.info:443'.
2019-02-13 12:02:15.177 (Hive) onDisconnect called for Hive Devices
2019-02-13 12:02:15.351 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:02:15.378 PluginSystem: Restarting I/O service thread.
2019-02-13 12:02:15.378 (Hive) Disconnect event received for 'api.prod.bgchprod.info:443'.
2019-02-13 12:02:15.380 (Hive) onDisconnect called for Hive Session
2019-02-13 12:02:24.807 (Hive) onHeartbeat called
2019-02-13 12:02:24.809 (Hive) Counter = 5
2019-02-13 12:02:34.831 (Hive) onHeartbeat called
2019-02-13 12:02:34.831 (Hive) Counter = 6
2019-02-13 12:02:44.853 (Hive) onHeartbeat called
2019-02-13 12:02:44.853 (Hive) Getting Data
2019-02-13 12:02:44.853 (Hive) Getting Weather
2019-02-13 12:02:44.853 (Hive) Transport set to: 'TCP/IP', api.prod.bgchprod.info:443.
2019-02-13 12:02:44.931 PluginSystem: Starting I/O service thread.
2019-02-13 12:02:44.931 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:02:44.932 (Hive) Transport set to: 'TCP/IP', weather.prod.bgchprod.info:443.
2019-02-13 12:02:44.950 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:02:45.100 (Hive) onConnect called for Hive Devices
2019-02-13 12:02:45.100 (Hive) Getting Devices
2019-02-13 12:02:45.101 (Hive) Sending 295 bytes of data
2019-02-13 12:02:45.151 (Hive) onConnect called for Hive Weather
2019-02-13 12:02:45.151 (Hive) Getting Weather
2019-02-13 12:02:45.152 (Hive) Received 530 bytes of data
2019-02-13 12:02:45.152 (Hive) Sending 152 bytes of data
2019-02-13 12:02:45.152 (Hive) onMessage called for Hive Devices
2019-02-13 12:02:45.153 (Hive) Transport set to: 'TCP/IP', api.prod.bgchprod.info:443.
2019-02-13 12:02:45.160 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:02:45.185 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:02:45.210 (Hive) Received 880 bytes of data
2019-02-13 12:02:45.211 (Hive) Disconnect event received for 'weather.prod.bgchprod.info:443'.
2019-02-13 12:02:45.212 (Hive) onMessage called for Hive Weather
2019-02-13 12:02:45.213 (Hive) onDisconnect called for Hive Weather
2019-02-13 12:02:45.313 (Hive) onConnect called for Hive Session
2019-02-13 12:02:45.313 (Hive) Creating Session
2019-02-13 12:02:45.314 (Hive) b'{"sessions": [{"username": "blah", "password": "blah", "caller": "WEB"}]}'
2019-02-13 12:02:45.314 (Hive) Sending 304 bytes of data
2019-02-13 12:02:45.364 (Hive) Received 670 bytes of data
2019-02-13 12:02:45.364 (Hive) Received 5 bytes of data
2019-02-13 12:02:45.365 (Hive) onMessage called for Hive Session
2019-02-13 12:02:54.834 (Hive) onHeartbeat called
2019-02-13 12:02:54.834 (Hive) Counter = 2
2019-02-13 12:03:04.807 (Hive) onHeartbeat called
2019-02-13 12:03:04.808 (Hive) Counter = 3
2019-02-13 12:03:14.823 (Hive) onHeartbeat called
2019-02-13 12:03:14.823 (Hive) Counter = 4
2019-02-13 12:03:15.128 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:03:15.173 (Hive) Disconnect event received for 'api.prod.bgchprod.info:443'.
2019-02-13 12:03:15.174 (Hive) onDisconnect called for Hive Devices
2019-02-13 12:03:15.345 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:03:15.374 PluginSystem: Restarting I/O service thread.
2019-02-13 12:03:15.375 (Hive) Disconnect event received for 'api.prod.bgchprod.info:443'.
2019-02-13 12:03:15.375 (Hive) onDisconnect called for Hive Session
2019-02-13 12:03:24.839 (Hive) onHeartbeat called
2019-02-13 12:03:24.839 (Hive) Counter = 5
2019-02-13 12:03:34.854 (Hive) onHeartbeat called
2019-02-13 12:03:34.855 (Hive) Counter = 6
2019-02-13 12:03:44.820 (Hive) onHeartbeat called
2019-02-13 12:03:44.820 (Hive) Getting Data
2019-02-13 12:03:44.820 (Hive) Getting Weather
2019-02-13 12:03:44.820 (Hive) Transport set to: 'TCP/IP', api.prod.bgchprod.info:443.
2019-02-13 12:03:44.827 PluginSystem: Starting I/O service thread.
2019-02-13 12:03:44.828 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:03:44.828 (Hive) Transport set to: 'TCP/IP', weather.prod.bgchprod.info:443.
2019-02-13 12:03:44.872 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:03:44.972 (Hive) onConnect called for Hive Devices
2019-02-13 12:03:44.972 (Hive) Getting Devices
2019-02-13 12:03:44.973 (Hive) Sending 295 bytes of data
2019-02-13 12:03:45.074 (Hive) onConnect called for Hive Weather
2019-02-13 12:03:45.074 (Hive) Getting Weather
2019-02-13 12:03:45.074 (Hive) Received 530 bytes of data
2019-02-13 12:03:45.074 (Hive) Sending 152 bytes of data
2019-02-13 12:03:45.074 (Hive) onMessage called for Hive Devices
2019-02-13 12:03:45.075 (Hive) Transport set to: 'TCP/IP', api.prod.bgchprod.info:443.
2019-02-13 12:03:45.094 (Hive) Connect directive received, action initiated successfully.
2019-02-13 12:03:45.095 (Hive) Queued asyncronous secure read aborted.
2019-02-13 12:03:45.144 (Hive) Received 880 bytes of data
2019-02-13 12:03:45.145 (Hive) Disconnect event received for 'weather.prod.bgchprod.info:443'.
2019-02-13 12:03:45.146 (Hive) onMessage called for Hive Weather
2019-02-13 12:03:45.146 (Hive) onDisconnect called for Hive Weather
2019-02-13 12:03:45.246 (Hive) onConnect called for Hive Session
2019-02-13 12:03:45.247 (Hive) Creating Session
2019-02-13 12:03:45.247 (Hive) b'{"sessions": [{"username": "blah", "password": "blah", "caller": "WEB"}]}'
2019-02-13 12:03:45.247 (Hive) Sending 304 bytes of data
2019-02-13 12:03:45.298 (Hive) Received 670 bytes of data
2019-02-13 12:03:45.298 (Hive) Received 5 bytes of data
2019-02-13 12:03:45.299 (Hive) onMessage called for Hive Session
2019-02-13 12:03:54.863 (Hive) onHeartbeat called
2019-02-13 12:03:54.866 (Hive) Counter = 2Code: Select all
2019-02-13 12:11:04.958 Error: Plugin: Connection Exception: 'resolve: Host not found (authoritative)' connecting to 'api.prod.bgchprod.info:443'
2019-02-13 12:11:15.023 Error: (Hive) Transport is not connected, write directive to 'Hive Devices' ignored.yes, that looks like the right one!Calzor Suzay wrote: Monday 18 February 2019 22:05 How do you get to the 0.7 version?
I click the file in github, history but not sure where/how to revert back to an old version?
Edit:-
Is this the link? https://github.com/imcfarla2003/domotic ... /plugin.py
