I erased persistent data and deleted the Zigate from the hardware tab so that I would start again fresh and capture the logs from the beginning.
After joining the Xiaomi temp sensor, it was working for about 15 minutes. Then I restarted the domoticz process and the values didn't update any more.
Is there anything in particular to search for in the logs or do I need to post the whole log file?
Here are the steps I followed:
- erase persistent data and "Update" button
click the zigate and "Delete" button
shutdown domoticz
start domoticz from command line with logging enabled
add the Zigate again, with join time = 255
press and hold the button on my 3A smart socket (issue #294 ) and it joined
tested turning the 3A smart socket and and off a couple of times from the web browser
stopped domoticz
started domoticz again
tried to use the browser to control the smart socket, it says it is turning off but it doesn't work
joined the Xiaomi temperature sensor
left it running for 15 minutes, noticed it was updating the temperature regularly
stopped domoticz
started domoticz
waited another 10 minutes, no temperature updates from the temp sensor and I still can't control the socket either
