Zigate plugin / devices not communicating after Domoticz restart
pocock
Post by pocock »
https://github.com/sasu-drooz/Domoticz- ... issues/295
I erased persistent data and deleted the Zigate from the hardware tab so that I would start again fresh and capture the logs from the beginning.
After joining the Xiaomi temp sensor, it was working for about 15 minutes. Then I restarted the domoticz process and the values didn't update any more.
Is there anything in particular to search for in the logs or do I need to post the whole log file?
Here are the steps I followed:
  • erase persistent data and "Update" button
    click the zigate and "Delete" button
    shutdown domoticz
    start domoticz from command line with logging enabled
    add the Zigate again, with join time = 255
    press and hold the button on my 3A smart socket (issue #294 ) and it joined
    tested turning the 3A smart socket and and off a couple of times from the web browser
    stopped domoticz
    started domoticz again
    tried to use the browser to control the smart socket, it says it is turning off but it doesn't work
    joined the Xiaomi temperature sensor
    left it running for 15 minutes, noticed it was updating the temperature regularly
    stopped domoticz
    started domoticz
    waited another 10 minutes, no temperature updates from the temp sensor and I still can't control the socket either
Daniel Pocock, Debian Developer
https://danielpocock.com
pipiche
Re: Zigate plugin / devices not communicating after Domoticz restart
Post by pipiche »
What do you mean by shutdown domoticz ? Do you mean you powered Off or it is only the domotciz service which has been stop ?
The question is mainly related to the Zigate in terms of did you Powered off Zigate ? There are on the zigate github some current discussion on losing Xiaomi devices after a power off .
Could you also let us know what is in the log, any activities ?
pocock
Post by pocock »
pipiche wrote: Sunday 16 December 2018 13:37 What do you mean by shutdown domoticz ? Do you mean you powered Off or it is only the domotciz service which has been stop ?
I was running the process in the terminal and I killed it with Ctrl-C, waiting for it to shut down, e.g.
su -s /bin/bash domoticz
cd /usr/lib/domoticz
/usr/lib/domoticz/domoticz ....... (start process)
Ctrl-C
pipiche wrote: Sunday 16 December 2018 13:37 The question is mainly related to the Zigate in terms of did you Powered off Zigate ? There are on the zigate github some current discussion on losing Xiaomi devices after a power off
No, I didn't power off the Zigate when doing those tests. I do power it off overnight usually, I am running it on my desk for testing during the daytime.
pipiche wrote: Sunday 16 December 2018 13:37 Could you also let us know what is in the log, any activities ?
I attached the log when I made the first post in this topic but the attachment doesn't appear to be visible, is there an issue with the forum? I've attached it again below. When I attach it, I notice an exclamation mark appears under the "Status" heading but there is no message about what that means.
pocock
Post by pocock »
pocock
Post by pocock »
as described in the Github issue, it looks like this was caused by the process trying to write to the directory where code is located (/usr/lib/domoticz/plugins/Domoticz-Zigate) which is read-only for the domoticz user, need to write the files elsewhere
pipiche
Post by pipiche »
@pocock a beta has been pushed on the zigate plugin github. This beta includes the possibility to customize the various folders.
Check: https://github.com/sasu-drooz/Domoticz- ... PluginConf
physiker123
Post by physiker123 »
I have the same issue as you had.
I did the git pull and I am in the beta branch.
Do I need to configure the PluginConf File? I do not really understand the parameters of that file... :(
Thank you in advance,
Jens
pipiche
Post by pipiche »
Here is where you can find information on the PluginConf
If you don't understand those parameters, please let us know where is the issue
physiker123
Thank you for the quick answer.
currently, the PluginConf.txt contains:
'CrcCheck':'On'
Do I need to add the following text from the wiki?
{ 'allowStoreDiscoveryFrames':'0', 'logFORMAT':'0', 'logLQI':'0', 'allowRemoveZigateDevice':'0', 'allowForceCreationDomoDevice':'0', 'networkScan':'0', 'channel':'0' }
Does this help? Sorry for bothering..
edit: I am running domoticz on a raspberry pi, the domoticz script folder is under /home/pi/domoticz/plugins/Domoticz-Zigate/
edit2: apparently I am still on the stable branch. I will try to update to the beta branch.
edit3: Now it says:
'channel':'11,15,16,21,22',
'self.eraseZigatePDM':'0',
'vibrationAqarasensitivity':'medium',
'resetMotiondelay':'30',
'enablegroupmanagement':'0',
'logLQI':'0',
'logFORMAT':'0'
Is the issue solved right now?
pipiche
Post by pipiche »
what is in the PluginConf.txt correspond to the default value parameters.
Could you clarify what your problem is ?
I'm also sceptical on the initial pluginconf.txt and I suspect that you were on the old version of the plugin . Didn't you have in the Log a message requesting you to upgrade ?
physiker123
Ok:
I had the problem of the not communication xiaomi-devices.
I thought I was on the beta branch, but I was on stable. So now I updated to the beta. In order to make a clean install, and since I have not a lot of devices, I also resettet my network.
My question now is, if the problem of non-communication is solved with the default values and files in the beta branch, or if I have to change any settings in the config files :)
pipiche
Post by pipiche »
You can stay with the default values, it should work and it works on various end users .
As the lost of Xiaomi devices, it was more related to the version 3.0e of the Zigate firmware which was loosing Xiaomi and non-Xiaomi devices when rebooting the system or powering-off/on. There is a pre-3.0f which fix that issue.
You can either stay on stable 4.0.7 or beta (which is becoming mature).
physiker123
Thank you very much for your response!
pipiche
Post by pipiche »
Official release 3.0f is available ....
