Dear..
Is there perhaps someone that is using a dummy gasmeter to see the usage of Kwh
I hope someone have this working so i can upload Kwh [ from my heatpump ] to www.mindergas.nl
What i am searching for is a dummy gasmeter, that is for real a kwh meter and this dummy have to count the actual and the total usage of the kwh meter.
When i have this working, i can upload this dummy gasmeter to www.mindergas.nl every day.
Fake Gasmeter
Derik
- Domoticz version: BETA
Fake Gasmeter
Derik
Re: Fake Gasmeter
I use a script to divide the Heatpump Kwh meter to 2Kwh to 1M3 gas.
And this Kwh meter is set to a dummy gas.:
DZ vents script Khw to Gas:
on = { timer = { "every 1 minutes"}}, --at 21:52 every minute
execute = function(dz)
local WarmtepompKWH = dz.devices('Z: WP Tot').counterToday
dz.log(WarmtepompKWH)
local WP_gas = dz.devices('D.M.: WP naar Gas')
local usage = WarmtepompKWH * 500
dz.log(usage)
WP_gas.updateGas(usage)
dz.openURL('http://192.168.5.70:8080/json.htm?type=command¶m=udevice&idx=12268&nvalue=0&svalue='..usage)
}And this total counter [ a Always total counter not for 1 day ] is needed for a good upload tot mindergas
www.mindergas.nl
SweetPants
Re: Fake Gasmeter
If i remember correct, there was a total counter in the passed, but it is removed. Total counters (per year) are now in the reports section. I'am afraid you have to calculate this yourself.
Derik
Re: Fake Gasmeter
So i must make a feature request?SweetPants wrote: Monday 04 February 2019 20:25 If i remember correct, there was a total counter in the passed, but it is removed. Total counters (per year) are now in the reports section. I'am afraid you have to calculate this yourself.
And do know what type of counter in the dummy section looks a gasmeter? so that have a total counter like the gasmeter?
Perhaps i can upload that on to mindergas..
- waaren
Re: Fake Gasmeter
No.
domoticz gas meter devices (real or virtual are the same internally) only store the total value in table deviceStatus. The daily usage is the result of a calculation (subtract max value from meter_calendar from current value)
So if you want to update the gas meter you should do something like
gas = domoticz.devices("your gas meter)
wpWHTotal=dz.devices('Z: WP Tot').WhTotal
gas.updateGas(wpWHTotal * 500)
