UserVariables not always set after Device Trigger Off[edit]
Freemann
- Domoticz version: >=Béta
Re: UserVariables not always set after Device Trigger Off[edit]
In de case of the Z-wave Off command, no change.
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann
Did some testing with the Z-Wave device and created an secundary script which triggers on the 2 UserVariable changes.
The original script to set the UserVariables send an email notification and the UserVariable change script also send a notification; The On command generates an email for both the UserVar's changes, the Off command not...
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann
Here's the script I use to test the UserVariables, no rocket science.:
Here another test with the strange behaviour of the Z-Wave device and the expected behaviour of the "Badkamer verlichting2" dummy device;
variables = {'BadkVerwarmingOffTime','BadkVerwarmingOnTime'}
logging = {
level = domoticz.LOG_DEBUG, -- change to LOG_ERROR after you tested the script
marker = "Return::on::variables::"
execute = function(dz, item, info )
local function logWrite(str,level) -- Support function for shorthand debug log statements
dz.log(tostring(str),level or dz.LOG_DEBUG)
dz.notify(tostring(str))
logWrite('UserVarTestScript:'..item.name..' :: changed to:'..item.value)
}Domotica/graphs "freak" :)
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
- waaren
Have to admit I am intrigued by this. Can you try and switch names of the Zwave and virtual device and check again ? This to see if the issue is caused by the name or by the different device types ?Freemann wrote: Thursday 31 January 2019 8:53 Here's the script I use to test the UserVariables, no rocket science.:
TIA
Freemann
Looks like it has something to do with the lenght of the devicename;
Devicename "Badkamer verlichtin" is working is expected
Devicename "Badkamer verlichting" is not working as expected
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
- waaren
On my system the length of the devicename does not influence the behaviorFreemann wrote: Thursday 31 January 2019 13:46 Looks like it has something to do with the lenght of the devicename;
- Spoiler: show
Freemann
Don't known if its matter, but thats a virtual/dummy device and i'm using a Z-Wave device.
When I use a dummy device with the name "Badkamer verlichting3", then it's also working fine; And the strange thing is... When I add a * the the "on" trigger in the script; "Badkamer verlichting*" both
Z-wave "Badkamer verlichting"
and
Dummy "Badkamer verlichting3"
are working as expected...
So;
Results in;
and
So;
--timer = {"every minute"},
devices = {
--237,
}}, -- 433 is sensor / isDevice Test switch
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann
Any idea what's causing it?
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
- waaren
I am sorry but no. I cannot reproduce the issue even with the exact same names. Until now no other forum member reported a similar issue with zwave devices so not much to work on either. Maybe if you switch on debug mode in dzVents and log to an OS file to show all relevant lines we will see more.
