UserVariables not always set after Device Trigger Off[edit]
Freemann
Domoticz version: >=Béta
Re: UserVariables not always set after Device Trigger Off[edit]
Post by Freemann »
In de case of the Z-wave Off command, no change.
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
Freemann
Post by Freemann »
Did some testing with the Z-Wave device and created an secundary script which triggers on the 2 UserVariable changes.
The original script to set the UserVariables send an email notification and the UserVariable change script also send a notification;
Screenshot - 30_01_2019 , 21_15_43.png (66.24 KiB) Viewed 733 times
The On command generates an email for both the UserVar's changes, the Off command not...
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann
Post by Freemann »
Here's the script I use to test the UserVariables, no rocket science.:
		variables = {'BadkVerwarmingOffTime','BadkVerwarmingOnTime'}
    logging =   {
        level     =   domoticz.LOG_DEBUG,       -- change to LOG_ERROR after you tested  the script
        marker    =   "Return::on::variables::"
	execute = function(dz, item, info )
        local function logWrite(str,level)             -- Support function for shorthand debug log statements
            dz.log(tostring(str),level or dz.LOG_DEBUG)
            dz.notify(tostring(str))
        logWrite('UserVarTestScript:'..item.name..' :: changed to:'..item.value)
Here another test with the strange behaviour of the Z-Wave device and the expected behaviour of the "Badkamer verlichting2" dummy device;
Screenshot - 31_01_2019 , 08_58_02.png (51.92 KiB) Viewed 726 times
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann wrote: Thursday 31 January 2019 8:53 Here's the script I use to test the UserVariables, no rocket science.:
Have to admit I am intrigued by this. Can you try and switch names of the Zwave and virtual device and check again ? This to see if the issue is caused by the name or by the different device types ?
TIA
Freemann
Post by Freemann »
Looks like it has something to do with the lenght of the devicename;
Devicename "Badkamer verlichtin" is working is expected
Devicename "Badkamer verlichting" is not working as expected
Screenshot - 31_01_2019 , 13_41_46.png (64.79 KiB) Viewed 718 times
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann wrote: Thursday 31 January 2019 13:46 Looks like it has something to do with the lenght of the devicename;
On my system the length of the devicename does not influence the behavior
-- isDevice check
    on =        {    devices  = { "isDevice Test with quite a very long name" }},  -- 433 is sensor / isDevice Test switch
        logging =   {
                        marker    =   "isDevice check"
        local trigger   = item.name
        local state     = item.state
        if info.trigger then
            trigger = info.trigger
            state   = "N/A"
        logWrite("triggered by " .. trigger .. "; state: " .. state .. "; isDevice        " .. tostring(item.isDevice ))
        logWrite("triggered by " .. trigger .. "; state: " .. state .. "; isVariable      " .. tostring(item.isVariable ))
        logWrite("triggered by " .. trigger .. "; state: " .. state .. "; isScene         " .. tostring(item.isScene))
        logWrite("triggered by " .. trigger .. "; state: " .. state .. "; isGroup         " .. tostring(item.isGroup))
        logWrite("triggered by " .. trigger .. "; state: " .. state .. "; isTimer         " .. tostring(item.isTimer))
        logWrite("triggered by " .. trigger .. "; state: " .. state .. "; isSecurity      " .. tostring(item.isSecurity))
        logWrite("triggered by " .. trigger .. "; state: " .. state .. "; isHTTPResponse  " .. tostring(item.isHTTPResponse))
        if item.isDevice then
            if item.state == "Off" then
                logWrite("triggered by " .. trigger .. "; state: " .. state )
                logWrite("setting uservar BadkVerwarmingOnTime to " .. os.time())
                dz.variables("BadkVerwarmingOnTime").set(os.time())
                logWrite("setting uservar BadkVerwarmingOffTime to " .. os.time())
                dz.variables("BadkVerwarmingOffTime").set(os.time())
2019-01-31 17:15:56.622  (Virtual2) Light/Switch (isDevice Test with quite a very long name)
2019-01-31 17:15:56.866  Status: dzVents: Info:  Handling events for: "isDevice Test with quite a very long name", value: "On"
2019-01-31 17:15:56.866  Status: dzVents: Info:  isDevice check: ------ Start external script: dumper103.lua: Device: "isDevice Test with quite a very long name (Virtual2)", Index: 1477
2019-01-31 17:15:56.868  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: On; isDevice        true
2019-01-31 17:15:56.869  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: On; isVariable      false
2019-01-31 17:15:56.869  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: On; isScene         false
2019-01-31 17:15:56.869  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: On; isGroup         false
2019-01-31 17:15:56.869  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: On; isTimer         false
2019-01-31 17:15:56.869  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: On; isSecurity      false
2019-01-31 17:15:56.869  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: On; isHTTPResponse  false
2019-01-31 17:15:56.869  Status: dzVents: Debug: isDevice check: setting uservar BadkVerwarmingOffTime to 1548951356
2019-01-31 17:15:56.871  Status: dzVents: Info:  isDevice check: ------ Finished dumper103.lua
2019-01-31 17:15:56.883  Status: Set UserVariable BadkVerwarmingOffTime = 1548951356
2019-01-31 17:16:05.613  (Virtual2) Light/Switch (isDevice Test with quite a very long name)
2019-01-31 17:16:05.843  Status: dzVents: Info:  Handling events for: "isDevice Test with quite a very long name", value: "Off"
2019-01-31 17:16:05.843  Status: dzVents: Info:  isDevice check: ------ Start external script: dumper103.lua: Device: "isDevice Test with quite a very long name (Virtual2)", Index: 1477
2019-01-31 17:16:05.844  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: Off; isDevice        true
2019-01-31 17:16:05.844  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: Off; isVariable      false
2019-01-31 17:16:05.844  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: Off; isScene         false
2019-01-31 17:16:05.844  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: Off; isGroup         false
2019-01-31 17:16:05.844  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: Off; isTimer         false
2019-01-31 17:16:05.845  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: Off; isSecurity      false
2019-01-31 17:16:05.845  Status: dzVents: Debug: isDevice check: triggered by isDevice Test with quite a very long name; state: Off; isHTTPResponse  false
2019-01-31 17:16:05.845  Status: dzVents: Debug: isDevice check: setting uservar BadkVerwarmingOnTime to 1548951365
2019-01-31 17:16:05.846  Status: dzVents: Info:  isDevice check: ------ Finished dumper103.lua
2019-01-31 17:16:05.883  Status: Set UserVariable BadkVerwarmingOnTime = 1548951365
uservar set by isDevice test
Freemann
Post by Freemann »
Don't known if its matter, but thats a virtual/dummy device and i'm using a Z-Wave device.
When I use a dummy device with the name "Badkamer verlichting3", then it's also working fine;
Screenshot - 31_01_2019 , 19_22_27.png (29.35 KiB) Viewed 713 times
And the strange thing is... When I add a * the the "on" trigger in the script; "Badkamer verlichting*" both
Z-wave "Badkamer verlichting"
and
Dummy "Badkamer verlichting3"
are working as expected...
So;
    on =        {
        --timer = {"every minute"},
                     devices  = {
                         --237,
Results in;
Screenshot - 31_01_2019 , 19_36_02.png (58.7 KiB) Viewed 710 times
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann
Post by Freemann »
Any idea what's causing it?
Lubuntu 19.04,
HarmonyElite
IP-Cam
Freemann wrote: Thursday 07 February 2019 18:48 Any idea what's causing it?
I am sorry but no. I cannot reproduce the issue even with the exact same names. Until now no other forum member reported a similar issue with zwave devices so not much to work on either. Maybe if you switch on debug mode in dzVents and log to an OS file to show all relevant lines we will see more.
