PiFace Doorbell working 3 / 10 times
jadijkstra2000
Post by jadijkstra2000 »
I have an RPI3 with Domoticz (stable) and a Piface Digital 2, for gas / energy montitoring, but.. also for my doorbell... the strange thing is however, 3 / 10 times (more or less), the input does not register the input strangly enough.. the button works fine...
I also tried the button on the PiFace itself, same story!
Any ideas why? I don't like the idea to create a wireless sensor or something, because the wires of the doorbell are already there... useless to go wireless when cables are in front..
But, it is very frustating when you expect a package :)
jvdz
Domoticz version: 4.107
Re: PiFace Doorbell working 3 / 10 times
Post by jvdz »
How is the doorbell switch connected?
Any PullUp resistor connected to the GPIO port used?
Jos
jadijkstra2000
No, internal pull-ip!
jvdz
Post by jvdz »
...and the answer to the first question is..? :)
jadijkstra2000
Well, to the question how it is connected.
Doorbell between ground and one of the inputs of the PiFace, and with an internal pull-up restitor, after pressing the door button, the input goes to 0.... :)
I have the same sort of issue with MySensors now, maybe cabling...
jvdz
Post by jvdz »
So the Doorbell is actually just the switch at the door itself which does a pulldown of the GPIO port and you are not having the piface parallel with the actual bell itself. That should indeed be a simple thing.
Jos
