Neo CoolCam Unknown: type=0200, id=1027 using NAS-WR01ZE
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
I've recently buy these NAS-WR01ZE , but when I add this to my domoticz ( version 4.10311) with zwave version :1.4-3311-g51da0ebc-dirty , it tells me that's a unknown device .
Also tried to exclude and include again but nothing ;(
What's wrong ;( Image
I already changed / edit the config xml's ,(and ex - include) without success
Last edited by thecosmicgate on Monday 21 January 2019 15:58, edited 1 time in total.
It's nice to be important, but it's more important to be nice
Scooter ;)
thecosmicgate
Re: Neo CoolCam Unknown: type=0200, id=1027 using NAS-WR01ZE
Nobody who can help me ;)?
Scooter ;)
bwbboot
Domoticz version: Latest
Post by bwbboot »
I have the same issue, however not sure if this is Domoticz related though. I guess this has to do with device identification in openzwave. Probably a good idea to report the issue there as well.
Doler
Post by Doler »
No problem with NAS-WR01ZE, I have three of these running without any problem. Maybe a defect unit?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
bwbboot
Post by bwbboot »
Yeah same here, i have a few running as well.
This might be a newer version of the device. I can see it reports a different version of the application and protocol version as well.
This is a correctly identified plug:
And this is a unknown plug:
thecosmicgate
Doler wrote:No problem with NAS-WR01ZE, I have three of these running without any problem. Maybe a defect unit?
The unit is working fine ! I can control it using domoticz, but domoticz can't read the configuration
Scooter ;)
thecosmicgate
bwbboot wrote:Yeah same here, i have a few running as well.
See here the information about the "unknown" plug Image
Scooter ;)
bwbboot
Post by bwbboot »
ok fixed locally. If you like you can request a perm fix through this method:
https://github.com/OpenZWave/open-zwave ... ng-Devices
edit your /domoticz/Config/manufacturer_specific.xml
search for NEO Coolcam and add this line
<Product type="0200" id="1027" name="Power plug 12A" config="shenzen_neo/nas-wr01z.xml"/>
Save and restart domoticz.
thecosmicgate
bwbboot wrote:ok fixed locally. If you like you can request a perm fix through this method:
Thnx but I think only restarting is not enough, I need to exclude and include this plug again ?
Scooter ;)
bwbboot
Post by bwbboot »
Was not needed here.
thecosmicgate
bwbboot wrote:Was not needed here.
Hmm okay , I entered this extra line , rebooted domoticz , still the unknown: type etc.
Trying with exclude ->include later today (@work now)
Scooter ;)
bwbboot
Post by bwbboot »
Did it work out? If not:
I realised I added the extra line to ~/open-zwave/config/manufacturer_specific.xml first, but without success. So thats why I added the extra line to ~/domoticz/Config/manufacturer_specific.xml. So maybe both locations need to be edited before it works?
You can also run ~/open-zwave$ sudo make xmltest to make sure you did not make a mistake editing the file.
thecosmicgate
Nope, it doesn't work as expected ;(
Still unknown, also after exclude -> exclude , so what's next to do ;) Image
Scooter ;)
bwbboot
Post by bwbboot »
you could move all zwcfg_*.xml files from~/domoticz/Config/ into a backup folder. And restart Domoticz.
thecosmicgate
Finally got it running !
But when I have a look in the available device (s) I was looking for the CM113 device to measure the Amp's but now I when I look at this CM113 device it measures Watt instead off Amp
Scooter ;)
pimseb
Domoticz version: 2020.1
Post by pimseb »
Hello
I have the same problem here, can't get this device being recognized :
Neo CoolCam Unknown: type=0200, id=1027+
What is this "+" after id ?
EDIT : got it working . HAd to add the line into the xml , restart domoticz, exclude node, include node
berrevoets
Domoticz version: 4.10240
Post by berrevoets »
Did have the same isue here istall the .xml files manual from beta packet
http://old.openzwave.com/snapshots/open ... 355.tar.gz
i just copy all files from the openzwave-1.4.33.55/config to domoticz/config (there are also new files in config/shenzen_neo)
did not now how to run the setup so i did this manualy
LouiS22
Post by LouiS22 »
pimseb wrote: Thursday 07 February 2019 19:47 Hello
"+" means it's a zwave plus device.
MultiZW074
Post by MultiZW074 »
Are you able to set device parameters now?
My coolcam type=0200 version won't update it's LED parameter for example.
Secondly the kWh measurement reads an abnormal 21474836.62 kWh
pimseb
Post by pimseb »
Yes it runs OK. I didnt check the led settings.
But everything seems to work fine in domoticz. The kWh mesure aswell
2019-02-11 23:03:18.097 (Zwave) General/kWh (kWh Meter)
2019-02-11 23:03:18.430 (Zwave) Usage (Poele)
2019-02-11 23:03:18.432 (Zwave) General/kWh (kWh Meter)
2019-02-11 23:03:18.898 (Zwave) General/Voltage (Voltage)
