Also tried to exclude and include again but nothing ;(
What's wrong ;(
I already changed / edit the config xml's ,(and ex - include) without success
The unit is working fine ! I can control it using domoticz, but domoticz can't read the configurationDoler wrote:No problem with NAS-WR01ZE, I have three of these running without any problem. Maybe a defect unit?
See here the information about the "unknown" plug
Thnx but I think only restarting is not enough, I need to exclude and include this plug again ?bwbboot wrote:ok fixed locally. If you like you can request a perm fix through this method:
https://github.com/OpenZWave/open-zwave ... ng-Devices
edit your /domoticz/Config/manufacturer_specific.xml
search for NEO Coolcam and add this line
<Product type="0200" id="1027" name="Power plug 12A" config="shenzen_neo/nas-wr01z.xml"/>
Save and restart domoticz.
Hmm okay , I entered this extra line , rebooted domoticz , still the unknown: type etc.bwbboot wrote:Was not needed here.
"+" means it's a zwave plus device.pimseb wrote: Thursday 07 February 2019 19:47 Hello
I have the same problem here, can't get this device being recognized :
Neo CoolCam Unknown: type=0200, id=1027+
What is this "+" after id ?
EDIT : got it working . HAd to add the line into the xml , restart domoticz, exclude node, include node
2019-02-11 23:03:18.097 (Zwave) General/kWh (kWh Meter)
2019-02-11 23:03:18.430 (Zwave) Usage (Poele)
2019-02-11 23:03:18.432 (Zwave) General/kWh (kWh Meter)
2019-02-11 23:03:18.898 (Zwave) General/Voltage (Voltage)
