Sharing : Afval kalendar in text sensor
Derik
- Domoticz version: BETA
Re: Sharing : Afval kalendar in text sensor
Dear Jos,
I do have the script in the inter editor... [ better for backups etc etc ]
This works with the "older" script good.
Only i did make a change with the config part
I changed to the last beta..
Now i do have a error.. Can you tell me what here is going wrong..
- jvdz
- Domoticz version: 4.107
Please show me the whole beginning of the script so I can check if the config part looks ok.
You can also pm it when you prefer.
Jos
Jos
Derik
jvdz wrote: Sunday 20 January 2019 21:07 Please show me the whole beginning of the script so I can check if the config part looks ok.
Jos
-- afvalWijzer module
-- curl in os required!!
-- create dummy text device from dummy hardware with the name defined for: myAfvalDevice
-- Check the timing when to get a notification for each Afvaltype in the afvaltype_cfg table
-- based on script by zicht @ http://www.domoticz.com/forum/viewtopic.php?t=17963
-- based on script by nf999 @ http://www.domoticz.com/forum/viewtopic.php?f=61&t=17963&p=174908#p169637
-- file: alvalwijzer_userconfig.lua
-- You can define your information in this file without updating the main script eachtime
myAfvalDevice='D.M.: Afval' -- The Text devicename in Domoticz
ShowNextEvents = 2 -- indicate the next x events to show in the TEXT Sensor in Domoticz
Postcode='6344AW' -- Your postalcode
Huisnummer='29' -- Your housnr
NotificationEmailAdress = "[email protected]" -- Specify your Email Address for the notifications. Leave empty to skip email notification
Notificationsystem = "" -- Specify notification system eg "telegram/pushover/.." leave empty to skip
-- uncoment any of the below when you need to override the standard settings
--~ -- Switch on Debugging in case of issues => set to true/false=======
--~ debug = false -- get debug info in domoticz console/log
--~ -- ### define a line for each afvaltype_cfg retuned by the webrequest:
--~ -- hour & min ==> the time the check needs to be performed and notification send when daysbefore is true
--~ -- daysbefore ==> 0 means that the notification is send on the day of the planned garbage collection
--~ daysbefore ==> X means that the notification is send X day(s) before the day of the planned garbage collection
--~ -- reminder ==> Will send a second reminder after x hours. 0=no reminder (needs to be in the same day!)
--~ -- text ==> define the text for the notification.
afvaltype_cfg = {
["restafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Grijze Container met Restafval"},
["gft"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Groene Container met Tuinfval"},
["pmd"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Oranje Container met Plastic en Metalen"},
["kerstbomen"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Kerstbomen"},
["takken"] ={hour=19,min=01,daysbefore=1,reminder=0,text="snoeiafval"},
["papier"] ={hour=12,min=05,daysbefore=0,reminder=0,text="Blauwe Container met Oud papier"},
["plastic"] ={hour=19,min=01,daysbefore=1,reminder=0,text="plastic en drankenkartons"},
["grofvuil"] ={hour=19,min=01,daysbefore=1,reminder=0,text="grofvuil/oud ijzer"},
["tuinafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="tuinafval"},
--~ -- Add any missing records above this line
--~ ["dummy1"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update for testing"},
--~ ["dummy2"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update of text sensor at night"}}
--~ -- Define the Notification Title and body text. there are 3 variables you can include:
--~ -- @DAG@ = Will be replaced by (vandaag/morgen/over x dagen)
--~ -- @AFVALTYPE@ = Will be replaced by the AfvalType found on the internet
--~ -- @AFVALTEXT@ = Will be replaced by the content of the text field for the specific AfvalType in afvaltype_cfg
--~ -- @AFVALDATE@ = Will be replaced by the pickup date found on the internet
notificationtitle = '@AFW: @DAG@ de @AFVALTEXT@ aan de weg zetten!'
notificationtext = '@DAG@ wordt de @AFVALTEXT@ opgehaald!'
--==== end of config ======================================================================================================
-- General conversion tables
local MON_e_n={January="januari", February="februari", March="maart", April="april", May="mei", June="juni", July="juli", August="augustus", September="september", October="oktober", November="november", December="december"}
local WDAY_e_n={Sunday="zondag", Monday="maandag", Tuesday="dinsdag", Wednesday="woensdag", Thursday="donderdag", Friday="vrijdag", Saturday="zaterdag"}
local MON={januari=1,februari=2,maart=3,april=4,mei=5,juni=6,juli=7,augustus=8,september=9,oktober=10,november=11,december=12}
-- round
break break
- jvdz
You have commented out the 2 dummy lines for the table and the last line is essential to close the Table syntax with the last }. Just leave them in there as they do serve a purpose!
Jos
afvaltype_cfg = {
Derik
Derik wrote: Sunday 20 January 2019 21:25jvdz wrote: Sunday 20 January 2019 21:07 Please show me the whole beginning of the script so I can check if the config part looks ok.
JosCode: Select all
-- afvalWijzer module -- -- curl in os required!! -- create dummy text device from dummy hardware with the name defined for: myAfvalDevice -- Check the timing when to get a notification for each Afvaltype in the afvaltype_cfg table -- based on script by zicht @ http://www.domoticz.com/forum/viewtopic.php?t=17963 -- based on script by nf999 @ http://www.domoticz.com/forum/viewtopic.php?f=61&t=17963&p=174908#p169637 ----------------------------------------------------------------- -- file: alvalwijzer_userconfig.lua -- You can define your information in this file without updating the main script eachtime ------------------------------------------------------------------------------------------ myAfvalDevice='D.M.: Afval' -- The Text devicename in Domoticz ShowNextEvents = 2 -- indicate the next x events to show in the TEXT Sensor in Domoticz Postcode='6344AW' -- Your postalcode Huisnummer='29' -- Your housnr NotificationEmailAdress = "[email protected]" -- Specify your Email Address for the notifications. Leave empty to skip email notification Notificationsystem = "" -- Specify notification system eg "telegram/pushover/.." leave empty to skip -- uncoment any of the below when you need to override the standard settings --~ -- Switch on Debugging in case of issues => set to true/false======= --~ debug = false -- get debug info in domoticz console/log --~ -- ### define a line for each afvaltype_cfg retuned by the webrequest: --~ -- hour & min ==> the time the check needs to be performed and notification send when daysbefore is true --~ -- daysbefore ==> 0 means that the notification is send on the day of the planned garbage collection --~ daysbefore ==> X means that the notification is send X day(s) before the day of the planned garbage collection --~ -- reminder ==> Will send a second reminder after x hours. 0=no reminder (needs to be in the same day!) --~ -- text ==> define the text for the notification. afvaltype_cfg = { ["restafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Grijze Container met Restafval"}, ["gft"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Groene Container met Tuinfval"}, ["pmd"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Oranje Container met Plastic en Metalen"}, ["kerstbomen"] ={hour=19,min=01,daysbefore=1,reminder=0,text="Kerstbomen"}, ["takken"] ={hour=19,min=01,daysbefore=1,reminder=0,text="snoeiafval"}, ["papier"] ={hour=12,min=05,daysbefore=0,reminder=0,text="Blauwe Container met Oud papier"}, ["plastic"] ={hour=19,min=01,daysbefore=1,reminder=0,text="plastic en drankenkartons"}, ["grofvuil"] ={hour=19,min=01,daysbefore=1,reminder=0,text="grofvuil/oud ijzer"}, ["tuinafval"] ={hour=19,min=01,daysbefore=1,reminder=0,text="tuinafval"}, --~ -- Add any missing records above this line --~ ["dummy1"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update for testing"}, --~ ["dummy2"] ={hour=02,min=10,daysbefore=0,reminder=0,text="dummy to trigger update of text sensor at night"}} --~ -- Define the Notification Title and body text. there are 3 variables you can include: --~ -- @DAG@ = Will be replaced by (vandaag/morgen/over x dagen) --~ -- @AFVALTYPE@ = Will be replaced by the AfvalType found on the internet --~ -- @AFVALTEXT@ = Will be replaced by the content of the text field for the specific AfvalType in afvaltype_cfg --~ -- @AFVALDATE@ = Will be replaced by the pickup date found on the internet notificationtitle = '@AFW: @DAG@ de @AFVALTEXT@ aan de weg zetten!' notificationtext = '@DAG@ wordt de @AFVALTEXT@ opgehaald!' --==== end of config ====================================================================================================== -- General conversion tables local MON_e_n={January="januari", February="februari", March="maart", April="april", May="mei", June="juni", July="juli", August="augustus", September="september", October="oktober", November="november", December="december"} local WDAY_e_n={Sunday="zondag", Monday="maandag", Tuesday="dinsdag", Wednesday="woensdag", Thursday="donderdag", Friday="vrijdag", Saturday="zaterdag"} local MON={januari=1,februari=2,maart=3,april=4,mei=5,juni=6,juli=7,augustus=8,september=9,oktober=10,november=11,december=12} -- round break break
MM Thanks!!
The red cross in gone..
So i hope this works again..
Can you give me some example of the options is can use for the text sensor and the mail message..
This is higher math for me.
xx
- jvdz
Nice...Derik wrote: Sunday 20 January 2019 22:09 MM Thanks!!
So i hope this works again..![]()
Not sure what you are asking here... could you explain?Derik wrote: Sunday 20 January 2019 22:09 Can you give me some example of the options is can use for the text sensor and the mail message..
Jos
Derik
notificationtext = '@DAG@ wordt de @AFVALTEXT@ opgehaald!' i can choose only how?
And perhaps a example how to use this:
- jvdz
Sorry but I am still lost on what you are asking as the quoted parts are an example of the described usage and the table is filled with records using the described options. PM me in Dutch in case you prefer that.
Jos
Jos
- jvdz
FYI: @JuanUil ; @freijn ; @rron & Others
I have added script_time_opzet.lua to github with the following commit message:
This script is a generic script for all gemeentes that use the service
of opzet.nl.
This makes the separate scripts for Pumerend, Zuidwest Friesland and
mijnblink (for the gemeentes: Laarbeek, Deurne, Gemert-Bakel,
Heeze-Leende, Someren, Asten en Nuenen) obsolete as they are supported
by this script. check their website for supported gemeentes:
http://www.opzet.nl/afvalkalender_digitaal
or check the afvalkalender of your gemeente and check whether it refers
at the bottom of the page to "Ontwerp & techniek: Opzet".
Also made a change today to fix the abbreviation for Maart from maa to mrt. Might happen again as the months pass by.
Jos
of opzet.nl.
Jos
Derik
Jos....
I did use the script into the intern lua editor, this was working fine.
Now i changed the head part of the script.. the script is not function any more
Hope you can see where there is something wrong..
There is something going on..
Only he says no thing to do?
Postcode='6678AW' -- Your postalcode
Huisnummer='1' -- Your housnr
afvaltype_cfg = {
-- round
function Round(num, idp)
return tonumber(string.format("%." ..(idp or 0).. "f", num))
-- debug print
function dprint(text)
if debug then print("@AFW:"..text) end
-- run curl and capture output
function os.capture(cmd, rep) -- execute command to get site
-- rep is nr of repeats if result is empty
local r = rep or 1
local s = ""
while ( s == "" and r > 0) do
r = r-1
local f = assert(io.popen(cmd, 'r'))
s = assert(f:read('*a'))
f:close()
if ( rep - r > 1 ) then
print("os.capture needed more than 1 call: " .. rep-r)
return s
-- get days between today and provided date
function getdaysdiff(i_afvaltype_date)
local curTime = os.time{day=timenow.day,month=timenow.month,year=timenow.year}
-- Calculate the daysdifference between found date and Now and send notification is required
local afvalyear =timenow.year
local afvalday =timenow.day
local afvalmonth=timenow.month
local s_afvalmonth="vandaag"
-- check if date in variable i_afvaltype_date contains "vandaag" in stead of a valid date -> use today's date
if string.lower(i_afvaltype_date) == "vandaag" then
-- use the set todays info
afvalday,s_afvalmonth=i_afvaltype_date:match("%a+ (%d+) (%a+)")
if (afvalday == nil or s_afvalmonth == nil) then
print ('! afvalWijzer: No valid date found in i_afvaltype_date: ' .. i_afvaltype_date)
return
afvalmonth = MON[s_afvalmonth]
dprint("...gerd-> afvalyear:"..tostring(afvalyear).." s_afvalmonth:"..tostring(s_afvalmonth).." afvalmonth:"..tostring(afvalmonth).." afvalday:"..tostring(afvalday))
local afvalTime = os.time{day=afvalday,month=afvalmonth,year=afvalyear}
-- return number of days diff
return Round(os.difftime(afvalTime, curTime)/86400,0) -- 1 day = 86400 seconds
function notification(s_afvaltype,s_afvaltype_date,i_daysdifference)
dprint("...Noti-> i_daysdifference:"..tostring(i_daysdifference).." afvaltype_cfg[s_afvaltype].daysbefore:"..tostring(afvaltype_cfg[s_afvaltype].daysbefore).." hour:"..tostring(afvaltype_cfg[s_afvaltype].hour).." min:"..tostring(afvaltype_cfg[s_afvaltype].min))
if afvaltype_cfg[s_afvaltype] ~= nil
and timenow.hour==afvaltype_cfg[s_afvaltype].hour
and timenow.min==afvaltype_cfg[s_afvaltype].min
and i_daysdifference == afvaltype_cfg[s_afvaltype].daysbefore then
print ('afvalWijzer Notification send for ' .. s_afvaltype)
dag = ""
if afvaltype_cfg[s_afvaltype].daysbefore == 0 then
dag = "vandaag"
elseif afvaltype_cfg[s_afvaltype].daysbefore == 1 then
dag = "morgen"
dag = "over " .. tostring(afvaltype_cfg[s_afvaltype].daysbefore) .. " dagen"
notificationtitle = notificationtitle:gsub('@DAG@',dag)
notificationtitle = notificationtitle:gsub('@AFVALTYPE@',s_afvaltype)
notificationtitle = notificationtitle:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtitle = notificationtitle:gsub('@AFVALDATE@',s_afvaltype_date)
notificationtext = notificationtext:gsub('@DAG@',dag)
notificationtext = notificationtext:gsub('@AFVALTYPE@',s_afvaltype)
notificationtext = notificationtext:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtext = notificationtext:gsub('@AFVALDATE@',s_afvaltype_date)
commandArray['SendEmail'] = notificationtitle .. '#' .. notificationtext .. '#' .. NotificationEmailAdress
-- Do the actual update retrieving data from the website and processing it
function Perform_Update()
print('afvalWijzer module start check')
dprint('=== web update ================================')
-- get data from afvalWijzer
local commando = "curl --max-time 5 -s 'https://www.mijnafvalwijzer.nl/nl/"..Postcode.."/"..Huisnummer.."/'"
local tmp = os.capture(commando, 5)
if ( tmp == "" ) then
print("afvalWijzer: Empty result from curl command")
return
-- strip html stuff and format for domoticz
tmp=tmp:gsub('%c','')
-- get the data for these fields
web_afvaldate,web_afvaltype=tmp:match('.-<p class="firstDate">(.-)</p>.-<p class="firstWasteType">(.-)</p>')
-- replace multiple spaces for only one
web_afvaltype = string.gsub(web_afvaltype, '%s+', ' ')
dprint("web_afvaltype:"..tostring(web_afvaltype).." web_afvaldate:"..tostring (web_afvaldate))
if (web_afvaldate == nil or web_afvaltype == nil) then
print ('! afvalWijzer: No valid data found in returned webdata. skipping the rest of the logic.')
return
-- set the date back to a real date to allow for future processing
if string.lower(web_afvaldate) == "vandaag" then
if WDAY_e_n[os.date("%A")] == nil then
dprint(" Error: Not in table WDAY_e_n[]:"..os.date("%A"))
if MON_e_n[os.date("%B")] == nil then
dprint(" Error: Not in table MON_e_n[]:"..os.date("%A"))
web_afvaldate = WDAY_e_n[os.date("%A")].." "..os.date("%d").." "..MON_e_n[os.date("%B")]
dprint('Change web_afvaldate "vandaag" to :' .. web_afvaldate)
-- process new information from the web
daysdifference = getdaysdiff(web_afvaldate)
if (afvaltype_cfg[web_afvaltype] == nil) then
print ('! afvalWijzer: Afvalsoort not defined in the "afvaltype_cfg" table for found Afvalsoort : ' .. web_afvaltype)
return
notification(web_afvaltype,web_afvaldate,daysdifference) -- check notification for new found info
dprint('=== device: ' .. myAfvalDevice .. ' check and update ========')
-- update device when text changed
local txt = ""
curdevtext = otherdevices[myAfvalDevice]
-- process each record in the device text first to check if still in future and notification needed
for dev_date, dev_afvaltype in string.gmatch(curdevtext..'\r\n', '(.-)=(.-)\r\n+') do
dprint("=> process:"..dev_date.."="..dev_afvaltype)
if web_afvaltype == dev_afvaltype then
dprint(".> skip same as current domoticz text -> dev_afvaltype:"..dev_date.."="..dev_afvaltype)
elseif afvaltype_cfg[dev_afvaltype] == nil then
dprint(".> skip dev_afvaltype as this doesn exist in table:"..dev_afvaltype)
-- Get DaysDiff
daysdiffdev = getdaysdiff(dev_date)
if daysdiffdev == nil then
-- something is wrong with the curent text, don't do anything
elseif daysdiffdev < 0 then
dprint(".> skip old -> dev_afvaltype:"..dev_date.."="..dev_afvaltype.." daysdiffdev:"..daysdiffdev)
dprint(".> Add back to TxtDev -> afvaltype:"..dev_date.."="..dev_afvaltype.." daysdiffdev:"..daysdiffdev)
notification(dev_afvaltype,dev_date,daysdiffdev) -- check notification for new found info
txt = txt..dev_date .. "=" .. dev_afvaltype .. "\r\n"
dprint('=== Update TxtDevice in Domoticz =============')
dprint("=> Add Webinfo to TxtDev -> afvaltype:"..web_afvaltype.." - "..web_afvaldate)
txt = txt..web_afvaldate .. "=" .. web_afvaltype
-- always update the domoticz device so one can see it is updating and when it was ran last.
if (curdevtext ~= txt) then
commandArray['UpdateDevice'] = otherdevices_idx[myAfvalDevice] .. '|0|' .. txt
print ('afvalWijzer: Update device from: \n'.. otherdevices[myAfvalDevice] .. '\n replace with:\n' .. txt)
print ('afvalWijzer: No updated text for TxtDevice.')
-- End Functions =========================================================================
-- Start of logic ========================================================================
timenow = os.date("*t")
-- check for notification times and run update only when we are at one of these defined times
local needupdate = false
for avtype,get in pairs(afvaltype_cfg) do
dprint("afvaltype_cfg :"..tostring(avtype)..";"..tostring(afvaltype_cfg[avtype].hour)..";"..tostring(afvaltype_cfg[avtype].min))
if timenow.hour==afvaltype_cfg[avtype].hour
and timenow.min==afvaltype_cfg[avtype].min then
needupdate = true
-- get information from website, update device and send notification when required
if needupdate then
debug = true -- activate debug here to only log the update process in detail
Perform_Update()
dprint("Scheduled time(s) not reached yet, so nothing to do!")
return commandArrayThere is something going on..
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :plastic;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :restafval;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :pmd;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :gft;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :dummy2;2;10
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :grofvuil;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :tuinafval;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :papier;12;5
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :takken;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:afvaltype_cfg :kerstbomen;19;1
2019-02-02 20:42:05.787 Status: LUA: @AFW:Scheduled time(s) not reached yet, so nothing to do! Xu4: Beta Extreme antenna RFXcomE,WU Fi Ping ip P1 Gen5 PVOutput Harmony HUE SolarmanPv OTG Winddelen Alive ESP Buienradar MySensors WOL Winddelen counting RPi: Beta SMAspot RFlinkTest Domoticz ...Different backups
- jvdz
The script will run each minute but It will only do something when one of the times in the table is equal to the actual time.
You have commented the debug=false line so it is showing the extra information like you see in the log.
You should actually not comment that line but change it to debug = true when you want to see the extra debugging information.
All clear?
Jos
All clear?
Jos
Derik
yes...
Only the script is not working any more...
The garbage days are not changing?
- jvdz
Ok, then show me the generate log when a the time it does the update process, so one of the times in the table is the actual time.
You can force this by using one of the dummy lines.
Jos
Jos
Derik
Time.. in the table?jvdz wrote: Sunday 03 February 2019 9:44 Ok, then show me the generate log when a the time it does the update process, so one of the times in the table is the actual time.
Jos
The script is running every ,minute...
And the force part i do not understand?
- jvdz
I know it is running every minute, but as I explained, it doesn't check the data on the website until one of the times in the table is equal to the current time!
Anyways, I looked at the posted code and that looks like an OLD version of the script and not the most recent version on GitHub, which indeed will not run properly in some cases.
Use that latest version from GitHub, update the info at the top and you should be good to go.
https://github.com/jvanderzande/mijnafv ... wijzer.lua
Jos
Jos
silver323
Installed the script into the intern lua editor but get an error in the log.
It was checking the following from the normal script:
I get the following error:
2019-02-06 12:05:10.389 Error: EventSystem: Warning!, lua script script_time_afvalwijzer has been running for more than 10 seconds
2019-02-06 12:08:27.962 Error: EventSystem: in script_time_afvalwijzer: /home/pi/domoticz/scripts/lua/JSON.lua:1009: /home/pi/domoticz/scripts/lua/JSON.lua:844: Lua script execution exceeds maximum number of lines
What's going wrong?
What's going wrong?
- jvdz
No idea. I am not using the internal script editor, but would start with checking the file /home/pi/domoticz/scripts/lua/JSON.lua to see whether it is valid or not in your installation.
Jos
Jos
silver323
It`s in the installation folder json.luajvdz wrote: Wednesday 06 February 2019 19:32 No idea. I am not using the internal script editor, but would start with checking the file /home/pi/domoticz/scripts/lua/JSON.lua to see whether it is valid or not in your installation.
Jos
The role numbers 844 and 1009 are not telling me anything to check.
But i will check if it's gone by putting the script in the lua folder.
Will let you know.
- jvdz
I have no idea what the limitations are of the build-in implementation, so just try to use it as a time script in a file to see whether that works.
Jos
Jos
silver323
Implemented as time script. But still get the same errors.jvdz wrote: Wednesday 06 February 2019 20:22 I have no idea what the limitations are of the build-in implementation, so just try to use it as a time script in a file to see whether that works.
Jos
