Dashticz - Module - Garbage collector Topic is solved
dvwerkhoven
Re: Dashticz - Module - Garbage collector
Post by dvwerkhoven »
Is it also possible to integrate the https://inzamelkalender.gad.nl/ for Hilversum ?
Ynco
Post by Ynco »
From 2019.01.01 mijnafvalwijzer doesn't work anymore ;( maybe someone knows which service works for Ede- i tried few but nothing works.
HansieNL
Post by HansieNL »
@Ynco : can you check mijnafvalwijzer again? Yesterday it didn't show info here, but now it does.
Blah blah blah
Ynco
Post by Ynco »
No, still the same "geen gegevens gevonden". I got on my phone message that from 2019 mijn avfal wijzer stops working. i had to download new app- ACV.
cyberclwn
Post by cyberclwn »
Ynco wrote: Tuesday 01 January 2019 11:52 From 2019.01.01 mijnafvalwijzer doesn't work anymore ;( maybe someone knows which service works for Ede- i tried few but nothing works.
I emailed with mijnafvalwijzer.nl about the garbage information of the ACV.
They said the ACV isn't working together with mijnafvalwijzer.nl anymore. So no information of ACV on mijnafvalwijzer.nl anymore.
but ACV has it own website/url:
http://www.acv-afvalkalender.nl/ which calls:
https://afvalportaal.2go-mobile.com/modules/f8e2844a-095e-48f9-9f98-71fceb51d2c3/kalender/calendar.html?294321&<street>---<number>%20%20%20---<postalcode>---EDE%20GLD---EDE
But my programming skills aren't up to level to get this fixed in the script.
Maybe it helps you guys :)
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
evildonkey
Domoticz version: 3
Post by evildonkey »
And knows if i can get it to work with the Gemeente Leiden?
Domoticz v3 - Beta Channel @ Pi3 | Harmoney Hub | MiLight Ibox2 | Google Home (1) | Google Home Mini (3)
Lokonli
Post by Lokonli »
evildonkey wrote: Sunday 20 January 2019 14:54 And knows if i can get it to work with the Gemeente Leiden?
Do you know whether Leiden provides a link to download the garbage calendar data?
evildonkey
Domoticz version: 3
could not find it on the website, i will send them a email.
evildonkey
Domoticz version: 3
Lokonli wrote: Monday 21 January 2019 19:17
If i put my postcode in there i can see when.
https://gemeente.leiden.nl/inwoners-en- ... ema-afval/
clsgroen2
Post by clsgroen2 »
dvwerkhoven wrote: Thursday 20 December 2018 22:58 Is it also possible to integrate the https://inzamelkalender.gad.nl/ for Hilversum ?
You can use ical for Hilversum eo:
- go to https://inzamelkalender.gad.nl/
- enter zipcode and housenr
- click 'naar maand- en jaarkalender'
- copy the url and configure in dashticz
BarryT
Domoticz version: 2024.3
Post by BarryT »
When using garbage, my dashticz keeps saying that i need a php enabled webserver..?
I'm trying to use mijnafvalwijzer, but whatever i do, it doesnt work at all :(
What did i doing wrong?
Raspberry / ESP Boards / Relais / Milight / Hue / OTGW / P1 / Xiaomi / RFXCom / RFLink / ZWave / Conbee II / Z2M / MQTT / A lot of scripts and many more..
Software: Linux, Android and Windows
HansieNL
Post by HansieNL »
@BarryT : Since version 2.4.6 for some functions a webserver with php is needed. It's described in the wiki.
Blah blah blah
BarryT
Post by BarryT »
I have nginx with php7.2 and the php-mod-curl installed..?
HansieNL
Post by HansieNL »
@BarryT : have you checked if your PHP is running fine. Can you check with http://<nginx-ip>:<nginx-port>/index.php
Blah blah blah
BarryT
Post by BarryT »
My php info is correct and the dashticz also works correct.. its just the garbage wich gives an error :(
ehelms
Post by ehelms »
Do any one know the code for ACV afvalwijzer?
BarryT
Post by BarryT »
I'm going to test on another server these days, maybe the curl didnt do its job correctly...
I'll let you know asap :)
Lokonli
Post by Lokonli »
BarryT wrote: Tuesday 12 February 2019 0:01 I'm going to test on another server these days, maybe the curl didnt do its job correctly...
You might need to install php-xml as well.
BarryT
Post by BarryT »
Lokonli wrote: Tuesday 12 February 2019 8:29
Okay, thnx for the tip!💪🏽
naitsirhc
Post by naitsirhc »
Could someone give me a walk through to configure my gmail calendar (Ical) with this nice add on?
Until now i've got:
config['garbage_icalurl'] = 'https://calendar.google.com/calendar/ic ... /basic.ics';
config['garbage_maxitems'] = '12';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
//gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
//pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
//Restabfallbehaelter: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
//papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
//kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
//brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
//black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
Restabfallbehaelter: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
//kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
Unfortunately my Dashticz does show up, but the garbage add on shows loading and doesn't continue....
thanks in advance
Und Tschjuß
